Conformal invariance of gluon amplitudes
pkwei99
Hi,
I'm very ashamed to not understand how even the simplest gluon amplitudes are conformally invariant. See eg http://arxiv.org/abs/hep-th/0312171 pages 11-12.
<br /> M(1^-,2^-,3^+)=\delta(\sum_i \lambda_i\tilde{\lambda}_i)\frac{\langle12\rangle^4}{\langle12\rangle \langle 23\rangle\langle31\rangle}<br />
the dilation operator is:
<br /> D\sim \lambda\frac{\partial}{\partial \lambda}+\tilde{\lambda}\frac{\partial}{\partial \tilde{\lambda}}+2<br />
First, I assume the dilation operator contains a sum over all particles. Next, Witten says the delta function carries weight -4 under D. Ok. Then he says that \langle 12\rangle^4 has weight 4. This I don't get. Doesn't it have weight 4 under just eg \lambda_1\frac{\partial}{\partial \lambda_1}
So
D \langle12\rangle^4=\sum_i (\lambda\frac{\partial}{\partial \lambda}+\tilde{\lambda}\frac{\partial}{\partial \tilde{\lambda}}+2)\langle12\rangle^4=[(4+0+2)+(4+0+2)+(0+0+2) ] \langle12\rangle^4?=14\langle12\rangle^4
Thanks for any help:)
Conformal invariance is obvious, because you're talking about the tree amplitude which simply reflects the classical behaviour of the theory. The Yang-Mills Lagrangian is classically conformal invariant. Only loop graphs break this symmetry. But if you want to explicitly verify conformal invariance from the MHV amplitude expression, I haven't studied enough to answer that.
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
