Conformal time closed Friedmann universe
In a closed Friedmann universe with a perfect fluid characterized by the equation of state p=wρc², transforming to conformal time τ reveals that the variable y=a^(1+3w)/2 follows a simple harmonic equation. The discussion emphasizes the importance of correctly applying the Friedmann equations, including the curvature term, and substituting the energy-pressure relation to derive the necessary equations. Participants highlight the need to express time derivatives in terms of conformal time derivatives and to avoid neglecting the curvature term in calculations. Ultimately, the analysis shows that all closed Friedmann models with the same equation of state share the same conformal lifetime. The conversation illustrates the complexity of cosmological models and the critical steps needed to solve them accurately.
Logarythmic
A closed Friedmann universe contains a single perfect fluid with an equation of state of the form p=w\rho c^2. Transforming variables to conformal time \tau using dt=a(t)d\tau, show that the variable y=a^{(1+3w)/2} is described by a simple harmonic equation as a function of \tau. Hence argue that all closed Friedmann models with a given equation of state have the same conformal lifetime.
2. The attempt at a solution
Please give me a starter. I haven't got a clue...
You'll want to start by writing down the Friedmann equations with curvature term +1, changing time derivatives to conformal time derivatives and substitute your energy/pressure relation. Do all this busy work and then think about the problem again.
So first the Friedmann eq. is
\left(\frac{\dot{a}}{a_0}\right)^2=H^2_0 \Omega_{0w} \left(\frac{a_0}{a}\right)^{1+3w}
and changing the time derivative like
\frac{da}{dt}=\frac{1}{a}\frac{da}{d\tau}
giving
\left(\frac{da}{d\tau}\right)^2=a^2a_0^2H_0^2\Omega_{0w}\left(\frac{a_0}{a}\right)^{1+3w}=H_0^2\Omega_{0w}a^{1-3w}a_0^{3+3w}=H_0^2\Omega_{0w}a^{1-3p/\rho c^2}a_0^{3+3p/\rho c^2}.
I still don't get it.
I don't get it either. That doesn't look like the first Friedmann equation to me. Where's rho? Where's the curvature term? You've already done a bunch of substitutions.
I have used the Friedmann equation
\left(\frac{\dot{a}}{a_0}\right)^2 - \frac{8\pi}{3}G\rho\left(\frac{a}{a_0}\right)^2 = H_0^2\left(1-\frac{\rho_0}{\rho_{0c}}\right) = H_0^2(1-\Omega_0) = -\frac{Kc^2}{a_0^2}
and
\rho a^{3(1+w)} = const. = \rho_{0w}a_0^{3(1+w)}
to get
\left(\frac{\dot{a}}{a_0}\right)^2=H^2_0 \left[\Omega_{0w} \left(\frac{a_0}{a}\right)^{1+3w} + (1-\Omega_{0w}) \right]
Then, for a curved model, the last term is negligible so
This is all from Coles Cosmology.
You are assuming the evolution is a power law in a(t) and it's not. The curvature term is not negligible. You are going to want to find an equation of the form b'=Kb where ' denotes the derivative wrt conformal time.
Well, then I'm back to zero and still stuck.
Ok, try this. Go back to the REAL Friedmann equation for H^2. We know this is a closed universe so it will reach a point of maximum expansion and then collapse. So pick t_0 to be the time of maximum expansion, so H_0=0, may as well take a_0=1 to make a choice of scale. Now put in your dependence of rho on and fix the constants at t_0. Now what does the equation look like?
Well. I actually worked through this in detail for practice. It does work. Substitute p=w*rho. Solve the H^2 eqn for rho and substitute it into the a'' one. Express the t derivatives in terms of conformal derivatives. Finally substitute y^(2/(3*w+1)) for a. You will get a y'' term, a (y')^2 term and a y^2 term. If you have actually managed to do all of the math correctly (it took me a few times), you will find the (y')^2 terms magically cancel (hence the choice of exponent). The remaining equation looks like a harmonic oscillator. Yahooo!
Uhm, what equations are H^2 and a''?
The H^2 equation is the one you have been working with, just involving rho. The a'' equation is the other Friedmann equation also involving the pressure and second derivative of the scale factor. If you substitute for the pressure in terms of rho you can combine them and eliminate the rho. Then work with that equation. Do NOT discard the curvature term.
And where did you get the a'' eq.?
