Confused about definitions in optics
The width of a pulse is defined in the time domain, while effective width describes this measurement. Spectral width refers to the range of wavelengths where the intensity is above a certain fraction of the maximum value, commonly specified using the full width at half maximum (FWHM) method. In optical communications, spectral width and frequency bandwidth are often treated similarly, as both indicate the range of frequencies where power remains significant. To convert between time and frequency domains, a Fourier transform is used, and spectral widths can be calculated by measuring the bandwidth at half intensity. Understanding these concepts is crucial for applications in optics and communications.
cytochrome
The width of a pulse is typically given in the time domain, correct? The effective width is the term to describe this.
What is the spectral width in the frequency domain?
How do you calculate spectral widths and effective widths?
Thanks for your time.
Science news on Phys.org
From wiki:
spectral width is the wavelength interval over which the magnitude of all spectral components is equal to or greater than a specified fraction of the magnitude of the component having the maximum value.
In optical communications applications, the usual method of specifying spectral width is the full width at half maximum. This is the same convention used in bandwidth, defined as the frequency range where power drops by less than half (at most −3 dB).
http://en.wikipedia.org/wiki/Spectral_width
Imagine you have a chart where the X axis runs from 500 nm to 550 nm and the Y axis is the intensity. If you plot the spectral width of a 525 nm laser you will see a very sharp peak in the center of your graph. But it's not perfectly sharp, you still have a range of wavelengths other than 525 nm. If you replaced the laser with an LED you would see much shorter, broader peak, as the LED has a wider band it emits in.
Frequency domain just means that you are plotting your graph with frequency instead of time.
Does that help?
That helps a lot, thank you. For some reason I couldn't find that wiki article.
So are frequency bandwidth and spectral width practically the same thing?
In optics, a pulse is a wavepacket and during its duration the frequency of the wave may vary or not. You have to perform a Fourier transform to pass from the time domain to frequency domain or vice versa. Once you have your plot you generally measure the band width at half its intensity (full width at half maximum, FWHM)
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
