Confused about forces - can anyone help?
  • Thread starter Thread starter peanutaxis
    Confused Forces
The discussion centers on the mechanics of a system involving a horizontal board attached to a vertical board via a pivot and a nail. When pulling on the horizontal board with force Fp, the forces acting on the vertical board must balance, leading to the equation Fp + Ff + F? = 0. The placement of the nail and hook affects the direction of force F?, which complicates the balance of horizontal forces in the second diagram. The torque generated by the forces must also be considered, as it influences the overall stability of the system. Ultimately, understanding the relationship between the forces and torques is crucial for resolving the apparent inconsistencies in the diagrams.
peanutaxis
In the first diagram below, there is a horizontal board and it is attached to a vertical board via a pivot, P, but is also hooked via a nail (red), and the vertical board is resting on the ground.
If I am pulling on the horizontal board with force Fp, and the whole setup doesn't move, then the forces on the vertical board are Fp, Ff, and F?. Since it is not moving Fp + Ff + F? = 0, and also the torques on the vertical board - due to Ff and F? - about P are equal and opposite (I should have made Ff look smaller).
In the second diagram (also nothing is moving) the nail and hook are now moved to the bottom. Fp is still the same, and Ff is also the same since the weight of the system and the frictioned ground are the same. Even F? is the same since the vertical board is still not rotating so the torques due to Ff and F? will still add to zero. But now F? is in the same direction as Fp, and so the horizontal forces aren't going to sum to zero anymore.
Intuitively, it shouldn't make any difference where you place the nail and hook. Wherever you place them, they will create the same torque about P, but all of a sudden it doesn't make sense in the second diagram.
What the heck is going on?:huh::huh::confused:
Yea who made this diagram? It dosen't seem consistent.
What's not consistent about it? In the first the vertical board experiences F? to the right, where the nail is. And in the second the vertical board experiences a F? to the left where the nail is.
How is there any torque around P if you are just pulling it straight on?
Without the nail and hook, there would be a torque on the vertical plank - due to Ff - and it would rotate CCW.
With the nail and hook the torque due to Ff is balanced by the torque due to F?
The question is, how on Earth to balance the horizontal forces overall, given that it shouldn't matter where the nail and hook is.
You've made a subtle error in your interpretation of Fp. (It might be easier to think of the hook and the pivot as two pins holding the two boards together and analyzing the forces on them, rather than thinking of a pivot and a hook).
I grab on to the horizontal board and tug on it with some force - let's call it Fh where the h stands for "handle", as if there's a handle on the horizontal board that I'm pulling on. Note that Fh and Ff are the external forces on the two-board system; if they are balanced the two boards won't move.
Now the important part: Fh is NOT the force at the pivot, Fp. Instead, the forces are related by (using the convention that left is the positive direction):
Fh = -(Fp + F?). Depending on where the hook is relative to the pivot, F? can be positive or negative, whatever is needed to generate a torque around the pivot that cancels the torque from Ff and then Fp will be whatever value is needed to make Fh come out to the the known horizontal force you're applying.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
