Confused about issues related to Time
  • Context: Graduate
  • Thread starter Thread starter kakram
    Confused Issues Time
The discussion revolves around the nature of time, particularly in relation to the cesium atom's measurement of a second, the effects of relativistic speeds, and the influence of gravitational fields, especially near black holes. Participants explore concepts of time dilation, the perception of time in different gravitational contexts, and the implications of being at or near a black hole.
  • One participant questions whether the measurement of a second by a cesium atom changes if the atom is moving close to the speed of light.
  • Another participant suggests that time stands still at the boundary of a black hole, while time flows differently as one moves away from it.
  • There is a discussion about whether time runs at infinity in areas of space with no gravitational pull.
  • Some participants propose that the definition of a second should account for the atom's motion and gravitational influence relative to the observer.
  • One participant speculates that if they were at the boundary of a black hole, they would observe distant objects aging at an accelerated rate, while others clarify that one cannot be physically stuck at the boundary.
  • Another participant notes that an infalling observer would experience time normally, contradicting the idea that time stands still for them.
  • There is a mention that a cesium atom measures a second consistently in its rest frame, regardless of the gravitational field, as long as it is in the same position as the observer.
Participants express differing views on the nature of time near black holes and the implications of relativistic effects on time measurement. There is no consensus on several points, particularly regarding the experience of time at the boundary of a black hole and the effects of gravitational fields on time measurement.
Participants highlight the complexity of defining time in varying gravitational fields and relative motion, indicating that assumptions about local time and gravitational influence are critical to the discussion.
kakram
A second is measured thus:
"the duration of 9,192,631,770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the cesium atom."
What if the cesium atom itself is moving close to the speed of light? Would that not change the time measured?
Also - at the centre of a black hole ... time stands still.. As one moves away from the black hole ... time starts moving again because less gravity ... if we keep moving away from heavy objects into an area of space where there is NO gravitational pull ... does time then run at *infinity*? Whats the upper limit of how 'fast' time flows?
I am getting a little confused when I think about there being no absolute time. Because even the duration of x periods of an atom - surely that 'duration' will change depending on if a) the atom is moving close to the speed of light, and b) what if it is at the centre of a black hole?
welcome to pf!
hi kakram! welcome to pf! :smile:
it means as measured in the rest-frame of the atom
(no, time stands still at the boundary of the black hole)
gravitational https://www.physicsforums.com/library.php?do=view_item&itemid=166" = √(g00(clock))/√(g00(observer)),
where g00 = 1 - R/r, r is distance, and R is the radius of the black hole …
so at r = ∞ ("where there is NO gravitational pull", as you put it), g00 = 1 (not 0) :wink:
Thank you for the quick reply..
ok... I sort of understand what you are saying... as I studied A level Physics 25 years ago and I'm no Feynman... any chance of an explanation in 'Laymans' terms ? :-)
You're absolutely right. Which is why the definition of a second should actually be the duration of x periods of an atom when that atom is not moving relative to you, and is not under some gravitational influence which is different to you.
In other words, the atom serves as a good definition of one second only when it is at the same position as you and has no relative motion to you. (since if it is at the same position as you, it must be in the same gravitational field as you).
Alternatively, you could measure the duration of x periods of an atom which was moving at some known speed relative to you, then calculate the time dilation to get the definition of a second.
OK.. starting to get clearer.
That means at the boundary of a black hole ... if *I* am there... my local time is still passing...
- people outside see *me* as stuck in time...
- I see people/stars/galaxies ageing and dying and rebirthing at super (infinite) speed?
If I am stuck at the boundary of a black hole - would I observe everything else (not at the boundary) passing infinitely faster? That seems to be the implication to me.
hi kakram! :smile:
you can't be stuck at the boundary, it's not physically possible …
(any body at the boundary has to "fall in")
you can be stuck just above the boundary, where everything distant passes, say, a billion times faster
and if you came back to Earth, you would find everything a billion times older :wink:
Yeah, this all seems right, as long as you replace the words "at the boundary" with "just outside the boundary"
Locally, time always seems to pass normally. (Unless you are inside a black hole, but in that case all the laws of physics break down).
Of course, in a very intense gravitational field (like that of a neutron star), the word 'local' must be defined over an extremely tiny space, so it is possible for a watch on your ankle to tick at a different rate to a watch on your wrist. (i.e. in some cases, the length scale of a person is not local enough for the curvature of spacetime to approximate 'flat').
Hrmm, to my knowledge an infalling observer would experience time at the normal rate that they always do for themselves, not have time stand still.
A second as measured by a caesium atom in its own rest frame is the same no matter what gravitational field it's in. That's implicitly shown in tiny-tim's 2nd line above, the time dilation is dependent on the clock's position AND the observer's position. Hence if the clock is in the same position as the observer (relative to the gravitational field), it's measuring time in its own rest frame; the numerator and denominator cancel and there is no time dilation.Edit - oops, I only read 2 replies before typing, maybe this comment is out of date.
  • · Replies 20 ·
  • · Replies 128 ·
  • · Replies 20 ·
  • · Replies 67 ·
  • · Replies 16 ·
