Confused about phase difference
Phase difference should be small when resonance is small because it indicates that the system is closely aligned with its natural frequency. When the forcing frequency matches the natural frequency, the phase difference between voltage and current becomes zero, signifying resonance. A swept-frequency plot of a parallel RLC circuit shows this relationship clearly, with voltage amplitude and phase difference represented distinctly. The resonant frequency in this case is 1000 Hz, emphasizing the importance of frequency alignment for minimal phase difference. Understanding this concept is crucial for analyzing circuit behavior at resonance.
znatale
Why should phase difference be small when resonance is small?
do you mean why should the phase difference be small when the forcing frequency and natural frequency are the same ?
Here is (in thumbnail) a swept-frequency plot of the voltage across a parallel RLC circuit. A constant current source (1 mA) is used. The resonant frequency is 1000 Hz. The voltage amplitude (solid line) is on the left. The phase (dotted line) is on the right. The phase difference (between voltage and current) equals zero when the forcing frequency and the natural frequency are the same.
Bob S
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
  • · Replies 20 ·
  • · Replies 37 ·
  • · Replies 19 ·
