Confused on a Certain Approximation/Expansion
  • Thread starter Thread starter ChrisJM
    Confused
The discussion centers on an approximation from Rolf Landauer's 1950 paper regarding the WKB method in quantum mechanics. The approximation states that if a is much greater than K, then the transmission coefficient A can be approximated as A = (b/a)^(1/2) to first order in K. Participants clarify that when a >> K, the small parameter ε = K/a allows for a Taylor expansion, leading to the approximation. Additionally, the value B, defined as K/2a, indicates that B is small, reinforcing that A approaches 1 while B approaches 0. The conversation aims to clarify the mathematical steps leading to the approximation of A.
ChrisJM
Hi, I need a quick bit of help for an approximation/expansion used in a paper by Rolf Landauer (1950). The paper deals with the WKB method (Quantum Mechanics) but that is irrelevant to my question. There is an approximation presented as follows:
A = 1 - (K/2a)
K = a - b
If a>>K, then A will be given by:
A = (b/a)^(1/2), to the first order in K
How is this approximation made? This is the entirety of the information provided: it is at the very start of the paper.
I've change a couple variable names (a and b are infact k1 and k2, the propogation constants in a potential well, if anyone is interested). A is the transmission coefficent of a wavefunction. I appreciate any help!
Cheers
Chris
Mathematics news on Phys.org
Hmm smells like one of those fishy physicists' "if f(x) = g(x) are equal to first order, they're equal" tricks :)
Where I got, is:
if a >> K then \epsilon = K/a is very small.
And then indeed, in first order,
\sqrt{1 - \epsilon} = 1 - \frac12 \epsilon + \mathcal O(\epsilon^2) = A + \mathcal O(\epsilon^2).
Now if there were a plus instead of a minus,
1 + \frac{K}{a} = \frac{a + b - a}{a} = \frac{b}{a}[/itex] <br /> and it would have been explained (sort of).<br /> Unfortunately, I think it should be a minus... but maybe this puts you on a track.
Hmm that could be the right direction.
Another bit I neglected to mention (but may help with the puzzle!), deals with another value B.
B = K/2a
And following the approximation that yields A = (a/b)^(1/2), it implies that this means that B>>A.
This obviously suggests that K/2a is very small, thus A is approximately 1 and B is approximately 0 (which fits with the following discussion). However, I'm still not sure how the approximation of A is done!
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
