Confused on potential energy losses and regain.
The discussion centers on calculating potential energy changes for a rubber ball dropping and bouncing back. The potential energy lost during the fall from 4.80m is correctly calculated as 151J. Upon bouncing back to 2.70m, the energy regained is 84.7J, leading to a net loss of potential energy of 66.3J. Clarification is provided that the 66.3J represents the net loss, while the 151J is the total energy lost during the fall. The correct approach emphasizes understanding the distinction between total energy loss and net energy loss after the bounce.
Lucyc2008
A 3.20kg rubber ball drops from a height of 4.80m to the ground a bounces back to a height of 2.70m
a) how much potential energy does the ball lose on the trip down?
b) how much energy does the ball regain on the trip back up?
c) what is the net loss of potential energy?
Ep = mgh
I got the question "correct" a) (3.20) x (9.80) x (4.80) = 151J b) (3.20) x (9.80) x (2.70) = 84.7J C) 151 - 84.7 = 66.3J but when studying for my test I found a completely different way of solving it by subtracting Ep2 (84.7) from Ep1 (151) so answer a) would be Ep lost = 67 instead. What is the correct way of solving this equation?. Attached is the second way of solving. The first way makes more sense in my mind because there is no height as the ball hits the ground so Ep = 0.
Ep = mgh
I got the question "correct" a) (3.20) x (9.80) x (4.80) = 151J b) (3.20) x (9.80) x (2.70) = 84.7J C) 151 - 84.7 = 66.3J but when studying for my test I found a completely different way of solving it by subtracting Ep2 (84.7) from Ep1 (151) so answer a) would be Ep lost = 67 instead. What is the correct way of solving this equation? The second way subtracting Ep2 from Ep1 makes more sense in my mind. Attached is the second way of solving.
In part (a) you are asked to find the loss of potential energy from the point of release to the point of contact with the floor. The answer to that is 151 J. The 67 J (or 66.3 J) is the answer to part (c), the net loss of potential energy which is also the loss of potential energy from 4.80 m to 2.70 m.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
