Finding the Relationship Between Volume and Surface Area of a Sphere
  • Thread starter Thread starter david18
    Confusing Indices
The discussion focuses on deriving the relationship between the volume and surface area of a sphere, defined by the formulas V=4/3πr^3 and S=4πr^2. To express surface area S in terms of volume V, one must first solve the volume formula for radius r and substitute it into the surface area formula. The solution for part a yields S=2^(2/3) * 3^(2/3) * π^(1/3) * V^(2/3). Conversely, to find volume V in terms of surface area S, the process involves reversing the steps used for part a. The conversation emphasizes the importance of proper mathematical notation and the challenge of eliminating the variable r from the equations.
david18
The Volume and surface area of a sphere is 4/3πr^3 and 4πr^2 respectively. V=4/3πr^3 and S=4πr^2. Write a) S in terms of V and b) V in terms of S
Im stuck on this question... I write out similar base units and stuff but it doesn't seem to work, any help?
-The answer to part a is S=2^2/3 3^2/3 π^1/3 V^2/3
Mathematics news on Phys.org
Apparently what you have to is solve each formula for r, and then plug into the the other.
So to solve part a) first, solve your Volume formula for r. then plug that into r in your S formula.
Just do the opposite to solve part b.
At least use grouping symbols properly if you do not have mathematical typesetting formatting. You intend to say
\[<br /> V = \left( {\frac{4}{3}} \right)\pi r^3 \quad S = 4\pi r^2 <br /> \]<br />
You should see through inspection that S is actually contained in the formula for V.
\[<br /> V = \left( {\frac{1}{3}} \right)(4\pi r^2 )r = \frac{{Sr}}{3}<br /> \]<br />
Right now, I do not yet see a way to completely eliminate 'r' from the formula. ...Should be possible though.
David18 has the right method. It will look a little messy but it will work. No need to bluntly show variable r.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
