Confusion about 2nd law of thermo
Entropy, measured in kJ/kg K, is not conserved, while energy, measured in kJ, is conserved within a system. When entropy increases, another form of energy, often free energy, decreases to maintain total energy conservation. There may be other categories of energy that also decrease as entropy increases. The discussion also draws an analogy with the value of beef, illustrating that while mass is conserved, value can fluctuate based on market conditions. This highlights the distinction between physical conservation laws and economic variables.
nate9519
Entropy has units of kJ/kg K and energy has units of kJ. So my question is if entropy is not conserved how is energy conserved when there is a unit of energy within entropy?
Science news on Phys.org
Hi nate:
In a system in which entropy increases, there will be another form of energy in the system which is decreasing so that the total energy is conserved. Generally this will be free energy, but AFAIK there technically might possibly be another category of energy other than "free energy" which would decrease as entropy increased.
See https://en.wikipedia.org/wiki/Free_energy .
Regards,
Buzz
If you have 90 lb of beef at $5/lb, the value of the beef is $450. Now the price goes up to $10/lb, and the value increases to $900. How come, if the value of the beef contains the mass of the beef as a factor, and mass is conserved, why isn't the value of the beef conserved?
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
