Confusion about The Conjugate Roots Theorem
The discussion centers around the Conjugate Roots Theorem in the context of polynomials with real coefficients. Participants explore the implications of the theorem, particularly regarding the nature of roots and the ability to graph polynomials in the Cartesian Coordinate Plane. The conversation touches on concepts of real and complex numbers, their relationships, and how they relate to polynomial behavior.
  • Some participants assert that there is no contradiction between the theorem and the initial statement about real coefficients, emphasizing that the polynomial can still be graphed even if it has complex roots.
  • Others argue that while the polynomial can be graphed, only real roots will intersect the x-axis, leading to confusion about the implications of having complex roots.
  • A participant highlights that the product of complex conjugate factors results in a real polynomial, which does not contradict the presence of complex roots.
  • Some participants express confusion about the distinction between the polynomial's coefficients being real and the roots being complex, seeking clarification on how both can coexist.
  • One participant introduces an example of a polynomial with rational coefficients that lacks rational roots, suggesting that the discussion could extend to more general cases beyond just real and complex numbers.
Participants generally agree that the polynomial can be graphed despite having complex roots, but there remains disagreement and confusion regarding the implications of real coefficients and the nature of roots. The discussion does not reach a consensus on the interpretation of the initial statements.
Some participants note that the initial statement about real coefficients does not preclude the existence of complex roots, but this point remains a source of confusion. The discussion also touches on the broader implications of field theory and the nature of roots in polynomials.
opus
As a preface to this theorem stated in my text, it states that:
"If all the coefficients of a polynomial ##P(x)## are real, then ##P## is a function that transforms real numbers into other real numbers, and consequently, ##P## can be graphed in the Cartesian Coordinate Plane."
It then goes on to state The Conjugate Roots Theorem:
Let ##P(x)## be a polynomial with only real coefficients. If the complex number ##a+bi## is a zero of ##P##, then so is the complex number ##a-bi##. In terms of linear factors of ##P##, this means that if ##x-(a+bi)## is a factor of ##P##, then so is ##x-(a-bi)##.
Now I understand the theorem, but what I've highlighted in bold is confusing me as it seems to be a contradiction. In the first statement, what I understand is that if we have real coefficients in a polynomial, then we'll have real numbers (and have no non-reals come up). In the theorem, it states the same given of only real coefficients, but now states that we can have non-real numbers come up. We then would not be able to graph all the solutions in the Cartesian Coordinate Plane.
Where am I thinking incorrectly here?
Mathematics news on Phys.org
There is no contradiction here. The point is that ##(x-a-ib)(x-a+ib) = x^2 - 2ax +a^2 + b^2## so even if it is factorised it into linear factors using complex numbers, the final result will be real if ##x## is real.
Edit: Let me add that, while you can graph the polynomial, only the real roots will be zeros of the graph. For example, ##y = x^2 + 1## has no real roots so its graph never crosses the ##x##-axis.
What do you mean by this? How can ##(x-a-ib)## or ##(x-a+ib)## be real if they have non-real constants? I understand up to the point where you factored the polynomial into linear factors which in this case have non-real constants in them.
I do understand that we can have polynomials of degree ##n## that will have at most ##n## solutions that may be real or non-real and distinct or non-distinct. If they are non-real solutions, they will not cross the x-axis and cannot be graphed in the Cartesian Plane.
opus said:
How can (x−a−ib)(x−a−ib)(x-a-ib) or (x−a+ib)(x−a+ib)(x-a+ib) be real if they have non-real constants?
I never said they were. I said their product is real. This follows directly from ##z\bar z## and ##z+\bar z## being real for any complex number ##z##.
What do you mean by this? Do you intend to say that the zeros will not be on the real line (true) or that you cannot graph the polynomial (false)?
Take ##P(x)=x^2+1=(x+i)(x-i)##. It has real coefficients ##1\cdot x^2 + 1##, its graph can be drawn, it doesn't cross the real line, and it has two complex and conjugate zeroes ##\pm \, i\,.##
So what don't you understand in this example?
The first bolded statement means that if you use a real number as an input value, then the output value will also be a real number. It is not a prescription that bars complex numbers from being used as input values. It simply has nothing to say about what happens if you use complex numbers that are not real numbers as input values.
The second bolded statement and the associated theorem tells us what will happen if the same polynomial has a complex root (a complex input that is associated with an output of 0). Neither statement contradicts the other.
Ohh ok. The product is real. Understood.
The first one. So to my understanding, only real zeros can be represented in the Cartersian Plane as it is two intersecting number lines consisting of real numbers.
I fully understand that example. I think I must have misunderstood the difference between ##P(x)## having real coefficients and the constants of the factors being non-real. In the given text, I was focusing on the statement that "If all coefficients of a polynomial are real, then ##P## is a function that transforms real numbers into real numbers", and thinking that this meant that if ##P(x)## has all real coefficients, then we can't get non-real numbers.
Yes this is exactly what was confusing me. I didn't really know how to word it correctly I guess. Sorry for the confusion guys and thanks so much for the replies.
You don't even need to use complex numbers. E.g. ##x^2-2## has rational coefficients, even integers, but no rational roots. Here we can draw a graph which crosses the ##x-##axis twice, just at locations which aren't rational. This entire matter is subject to field theory. In this example you can add - terminus technicus is adjoint - the square root of ##2## and all its sums and rational multiples to the rationals and obtain ##\mathbb{Q}[\sqrt{2}]## which has the zeros required. But then you won't have zeros for ## x^2-3##. Latest in the field of complex numbers are all roots (= zeroes) of all polynomials included. However, this doesn't mean we can write them down as expression of roots, only that they exist in there and can be numerically approximated.
  • · Replies 17 ·
  • · Replies 0 ·
  • · Replies 35 ·
  • · Replies 16 ·
