Chemistry Confusion in relation of Gibbs free energy and equilibrium constant
The discussion centers on calculating the equilibrium constant (Kp) for the reaction SO2(g) + 1/2O2(g) ⇌ SO3(g) at 298 Kelvin, using Gibbs free energy (ΔG) and thermodynamic equations. ΔG is calculated as -70.01 kJ/mol, leading to Keq = e^28.25, which equals 1.86 x 10^12. The confusion arises regarding whether Keq corresponds to Kp or Kc, as both can apply depending on the measurement context, with Kp relating to partial pressures and Kc to concentrations. The standard state for gases is defined as 1 bar, indicating that in this case, Keq is Kp, as the reaction involves gases. Understanding the relationship between Kp and Kc is crucial for accurate calculations in thermodynamics.
tbn032
for the reaction
SO2(g)+(1/2)O2(g)⇌SO3(g);ΔH=-98.32KJ/mole,ΔS=-95J/(mole-K).
find Kp at 298 Kelvin?
SO2(g)+1/2O2(g)SO3(g);ΔHo=-98.32KJ/mole,ΔSo=-95J/(mole-K).
In given question at first Δ G will be calculated using formula ΔG = Δ H – T x ΔS, by putting the given values in formula we get ΔG = -70.01 kJ/mol.
Then Keq will be calculated using equation = Δ G = -RT ln Keq ,ln Keq = -70010J/-8.314 x 298 = 28.25 .or Keq = e28.25 = 1.86x1012.
Now my confusion is Keq=Kpor Keq=Kc(depending on if we measure the equilibrium constant in terms of pressure or molarity, gases can be measured in both).and
Kp = Kc(RT)Δn and Δn=-1/2(for this reaction).
No information about the pressure or concentration is given so how do I conclude that Keq=Kp or Keq=Kc and thus calculate the correct value of Kp
Given the temperature 298 Kelvin, is this reaction at the 'standard state'? If so, the pressure is ambient or ~1 atm (100 kPa, or 1 bar).
https://en.wikipedia.org/wiki/Standard_state#Conventional_standard_states
Given the standard state, one should be able to determine the density of the gases. What does one's textbook indicate about STP, standard state and Gibbs free energy?
The problem statement one provides indicates gases.
my confusion is arising from the fact that in my book it is written that
Δ G = -RT ln Keq
Keq=KporKc as the standard state is referred in terms of partial pressure or concentration
Δ G = -RT ln Kp
Δ G = -RT ln Kk
if calculate the value of Keq from the equation Δ G = -RT ln Keq using R=8.3144598J⋅K-1⋅mol-1.the value of Keq is dimensionless
so I am not able to conclude if Keq=Kp or Keq=Kc
kp≠kc because Kp = Kc(RT)Δn and Δn=-1/2(for this reaction).
The standard state for gases is 1 bar. So, in this example, the Keq is Kp. It is in terms of the partial pressures of the components in bars.
Incidentally, you omitted the superscript 0 in ##\Delta G^0##
Likes Lord Jestocost
tbn032 said:
Homework Statement:: for the reaction
Relevant Equations:: SO2(g)+(1/2)O2(g)⇌SO3(g);ΔH=-98.32KJ/mole,ΔS=-95J/(mole-K).
The equation is giving it up as you have SO2(g) you are dealing with gases
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
