Confusion regarding the scalar potential
lampCable
Consider the following in cylindrical coordinates \rho,\varphi,z. An electric current flows in an infinitely long straight cylindrical wire with the radius R. The magnetic field \mathbf{B} outside of the thread is \textbf{B}(\textbf{r})=\frac{I\mu_0}{2\pi}\frac{\mathbf{e}_{\varphi}}{\rho}, ρ>R. We want to determine wether \mathbf{B} has a scalar potential or not.
Since the domain is not simply connected, there is no use showing that \nabla\times\mathbf{B}=\mathbf{0} for ρ>R. Therefore, we must show that for all points P and Q the line integral of \mathbf{B} from P to Q is independent of path, since this implies that \mathbf{B} has a scalar potential.
Consider a circle, C, that is concentric with the cylindrical wire with radius R_1 such that R_1>R. Line integration of \mathbf{B} over the closed curve C yields \oint_C\mathbf{B}⋅d\mathbf{r} = [d\mathbf{r} = R_1d\varphi\mathbf{e}_{\varphi}] = \frac{I\mu_0}{2\pi}\int^{2\pi}_0\mathbf{e}_{\varphi}⋅\mathbf{e}_{\varphi}d\varphi = I\mu_0 \neq 0. But this says that \mathbf{B} is dependent of path, and therefore \mathbf{B} does not have a scalar potential.
However, if we now consider the function \phi(\varphi) = \frac{I\mu_0}{2\pi}\varphi, we observe that \nabla\phi = \frac{1}{\rho}\frac{I\mu_0}{2\pi}\mathbf{e}_\varphi = \mathbf{B}. But this says that \mathbf{B} is independent of path, and therefore \mathbf{B} has a scalar potential.
And so, we end up with a contradiction. Since I am very confident that the line integral of \mathbf{B} over C is correct, I assume that there is something in the last part that is wrong, but I cannot find the error.
Your problem here is that \varphi lies between 0 and 2\pi, but both \varphi = 0 and \varphi = 2\pi represent the same physical half-plane. Thus if \phi = k\varphi, k \neq 0, then there is a half-plane where \phi is discontinuous: from one side \phi \to 0 and from the other \phi \to 2k\pi. This is a problem for the existence of \nabla \phi *everywhere* in \rho > R.
To avoid this problem, physically acceptable scalar or vector fields are always periodic in \varphi with period 2\pi.
(The other way to avoid this is to admit multivalued potentials, in which case yes, \nabla (k\varphi) = (k/\rho)\mathbf{e}_{\varphi}.)
Likes lampCable
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
