Confusion regarding the speed of sound in wind
The discussion centers around the question of how wind affects the speed of sound in air. Participants explore theoretical and conceptual aspects of sound propagation in moving media, examining whether the speed of sound is influenced by the velocity of the wind or remains constant regardless of the wind's presence.
  • One participant suggests that the speed of sound should be the vector sum of the wind speed and the speed of sound in still air, while later reasoning indicates that the speed of sound remains constant regardless of wind velocity.
  • Another participant challenges this reasoning by comparing sound propagation in still air to swimming in a pond versus a current, suggesting that the frame of reference affects the perceived speed of sound.
  • A claim is made that sound is not transmitted by the net translation of air particles, implying that wind should not affect sound propagation time if the bulk modulus remains unchanged.
  • Participants discuss the importance of the frame of reference, with one clarifying that the ground is the stationary frame in which wind velocity is measured.
  • One participant argues that the dynamics of sound transmission are altered by the movement of the medium, using an example of sound propagation in a wind tunnel to illustrate how the source and destination points change relative to the medium.
  • Another participant acknowledges the limitations of modeling gases as lattices of particles, emphasizing that sound speed is constant with respect to the medium under specific conditions.
Participants express differing views on whether the speed of sound is affected by wind, with some arguing for the vector sum approach and others maintaining that sound speed remains constant in a moving medium. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight the dependence of sound speed on the medium's properties and the frame of reference, noting that assumptions about the behavior of sound in moving media may not hold under all conditions.
CooperPears
One of my students asked me the seemingly innocuous question of "how does wind affect the speed of sound?". My immediate thought was that the velocity of the wave would be the vector sum of the velocity of the wind and the velocity of sound waves in still air. However, upon further reflection I came to the conclusion that the wave should have the same velocity regardless. My reasoning is this: the speed at which the disturbance propagates THROUGH the medium should not affected by the velocity of the medium itself. Imagine that the air is a lattice of tiny particles connected by springs. Whether or not the lattice is moving as a whole would have no effect on the time it would take for a disturbance to travel between two arbitrary points. In short the dynamics of how the disturbance gets transmitted through the medium have not been altered by the introduction of a medium velocity. Thus the way I see it is that unless wind appreciably changes the bulk modulus of air, then the velocity should remain the same.
I have read some forum responses online that indicate my reasoning is flawed, and that my first impression of the system was indeed correct and that the velocity is just a superposition. If so, can you help me identify the flaw in this logic?
Thank You
In fluid dynamics we conventionally model the medium of air to be like static particles, the scenario you have described here is the opposite. An analogy that might help you understand is a static pond, imagine swimming through there and now compare that to swimming through a sea full of currents. Whilst swimming through a sea full of currents it's quite obvious that your velocity can be modeled by the vector sum of the current and yourself. Your chain of reasoning is also dependent on the frame of reference of the observer, so can you please clarify?
Your thinking would apply if sound was transmitted by air particles moving from source to observer but that is not true.
Could you clarify the frame of reference?
the frame of reference is stationary ground i.e. the one in which the wind velocity is measured
If your frame of reference is the ground then the speed of sound from your perspective will be the speed of the medium + speed of sound through the wind
Well the flaw in the logic is really that air (or any gas) is not a lattice of molecules interconnected by springs. That more accurately describes a solid. Even then it would still be dependent on the motion of the lattice when observed from a stationary frame.
For a given set of of conditions, the speed of sound is constant with respect to the medium of travel. If a stationary observer is standing in the wind, he or she will observe sound waves moving at a velocity that is the vector sum of the sound speed at those conditions and the wind speed.
You are of course correct in that it is not prudent to model a gas as a lattice of particles connected by springs. I was not suggesting we use that model, but since I am referring to the stiffness (bulk modulus) of air, I thought that would get my point across but clearly it didn't. Apologies.
Like you said, the speed of sound w.r.t to the medium is constant for a set of conditions. What I am saying is that since wind is the net translation of air particles, and sound is not transmitted by the net translation of air particles, it shouldn't affect the time it takes the sound to travel between two points. Assuming of course that wind and still air have the same bulk modulus.
Your last line seems to be arguing in favour of your "immediate thought" rather than your "further reflection".
Agreed. This odd argument with yourself seems like it should come to one conclusion, not two different ones.
You're assuming that the source and destination points stay in the same positions relative to the medium in the case with a medium velocity as in the case with no medium velocity. They don't.
Imagine a speaker which emits a very short chirp, which is then detected by a microphone 340 meters down a wind tunnel. Assume that the conditions in the wind tunnel are adjusted so that the speed of sound is 340 meters per second.
First, we do the experiment with no wind, and we measure the chirp at the microphone 1.000s after the speaker sounded.
Next, we set the wind tunnel to provide a 10m/s wind from the speaker to the microphone. After 34/35 of one second has passed, the position in the medium where the sound originated is 9.714m away from the speaker, and the sound wave has traveled 330.286m within the medium, reaching the microphone.
Basically, a moving medium invalidates your assumption that the source and destination stay the same distance apart within the medium.
You seem to be misinterpreting this part. Uniform bulk translation of air particles doesn't constitute sound, but it does effect the propagation speed of sound created otherwise.
  • · Replies 40 ·
  • · Replies 23 ·
  • · Replies 236 ·
18K
  • · Replies 26 ·
13K
