Confusion with proper time from different frame of references
Stevey_R
I'm having trouble getting my head around the idea of 'proper time'. I've been thinking of this situation and I can't seem to understand what exactly the proper time is.
Say we have a planet 'A' and a rocket B moving towards this planet. From the perspective of A, B is moving towards A. If an observer on A timed how long it takes for B to reach A then would this be the proper time?
If it is the proper time then that would assume B measures a longer time to reach A. But then if an observer on A looks at B's clock as it arrives then they would see a higher time. Surely that's not possible if B appears to slow down relative to A?
If we assign proper time as measured from the rocket, then we arrive at the same problem if we take B's frame of reference where planet A is approaching B.
Sorry if I'm being completely ignorant here but it's been bugging me for a while. Hope my explanation will suffice :)
Proper time is "time" as it is experienced by each observer.
A's proper time differs from B until they stop moving relative to each other.
As to who's time is shorter, that depends on who had to do the stopping relative to the other.
i.e. if B lands on A, then B underwent acceleration which is not relative, (of course this ignores the mechanics of A's rotational frame of reference), but the point is, B had to initiate dynamic action to enter A's reference frame. A on the other hand, takes no dynamic/kinematic action.
This breaks the symmetry between A and B, and B's clock is found to have run slower.
It's rather simple: the proper time of an observer (regardless how he moves, with constant velocity or accelerated; and regardless of any other reference frame) is the time which he measures using a co-moving clock.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
