Connection between Cybernetics and Divine Proportion
  • Thread starter Thread starter Radix
    Connection
Radix
I think I may have discovered something unique to mathematics. I made a (sloppy) webpage to explain:
http://www.angelfire.com/planet/cybernetics/
Mathematics news on Phys.org
I doubt it's anything big, but I guess it's pretty neat that Phi can be applied again.
It just doesn't seem you proved it for the general case.
So far, it's only a conjecture.
What pure nonsense, surely this is a joke right?. The relative size of those cascading images you got when you pointed your webcam at your monitor are simply a function of the relative size of the camera's field of view and the size of the screen.
Also you don't even know the difference between +ive and -ive feedback. When you point the camera at the screen it's actually positive feedback, not negative as you claim. Positive feedback doesn't necessarily lead to a system that blows up exponentially, if the loop gain is less than one then positive feedback systems are also stable. Also negative feedback system don't necessarily oscillate, there is so much rubbish on that page it's ridiculous.
regardless of whether its positive or negative you still get phi. I've done it more than once using different angles with different measurements. The size of my monitor or the field of view of my camera have nothing to do with it. Try it yourself and you will get phi also.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
