Consequences of Rotating Objects C on Coil A Frequency
2 replies · 2K views
AAB1994
As per the above figure coil A is situated inside a magnetic field caused by small accelerating objects B which in turn are causing the larmor frequency in coil
Object C or train of objects C have quadruple movement and are rotating around the coil A giving out gravitational waves.
Objects C are rotating with the source of magnetic or em field ( or are cause of it)
In above situation:Would there be acceleration of particles in coil A if the frequency of gravitational waves given out by objects C is double of larmor frequency? (As per parallel propagation given in the paper no.1,2, and 3)If we assume objects C to be rotating clockwise then in which direction(E or F) would the particles at point N accelerate (paper no.4 also shows the generation of em waves by accelerated particles) and if we they accelerate in one direction could the energy be highest at center of the coil depending on the direction of the coil.And would the above answers differ if the objects C were also generating magnetic fields through their acceleration (as the source of larmor precession on Coil A)
Papers
1)http://cdsads.u-strasbg.fr/cgi-bin/..._paper=YES&type=PRINTER&filetype=.pdf
2)http://articles.adsabs.harvard.edu/cgi-bin/nph-iarticle_query?1981ApJ...248..783P&data_type=PDF_HIGH&whole_paper=YES&type=PRINTER&filetype=.pdf
3)https://arxiv.org/pdf/gr-qc/9905054.pdf
4)https://arxiv.org/pdf/1502.00893.pdf
on Phys.org
B can be seen as current loop
