Conservation of Angular momentum question.
The discussion focuses on a physics problem involving the conservation of angular momentum after a collision between a mass and a stationary cylinder. The initial angular momentum of the system is calculated using the mass and velocity of the object striking the cylinder. The moment of inertia for the combined system is determined, and the final angular velocity is sought. A participant notes the importance of using angular momentum rather than linear momentum in the calculations. The conversation emphasizes the need for correct unit conversions and understanding the principles of angular momentum to solve the problem accurately.
greg_jones20
An object of mass 25gm and horizontal velocity of 125 cm/s strikes and sticks to the top of a cylinder of mass 333gm and radius 25cm at rest.
a) Use conservation of angular momentum to determine the final angular velocity of the combination after the collision.
b) What is the change in the kinetic energy of the system?
Angular Momentum(L) = IW, where I is moment of inertia and W is angular velocity. and
Momentum(P) = mass(m)*velocity(v),
Lo = Lf
m1*Vo + I*Wo = If*Wf [here, Wo=0, m1=25gm, If=1/2(m1+m2)R^2, Wf = Vf/R]
(.025kg)(1.25m/s) + 0 = [1/2(.025kg+.333kg)(.25m)^2]Vf
Tried to solve for Vf from above eqn. but couldn't get the units to work out correctly.
Linear momentum p and angular momentum L are not the same thing. You need to use the angular momentum of the first object, not its linear momentum, in your conservation of angular momentum equation.
