Conservation of angular momentum.
Angular momentum is conserved around the bottom left corner of the described system because there are no external torques acting on it. The setup involves a square and a leaping mass, with the center of mass being crucial for analysis. Gravity, while acting on the system, does not exert a torque about the bottom left corner due to its line of action passing through that point. This means that the gravitational force does not create a moment arm, thus not affecting angular momentum conservation. Understanding these principles clarifies why angular momentum remains conserved in this scenario.
peripatein
Why is angular momentum conserved around the bottom left corner in the following set up (see attachment)? The attachment shows a square of side a and mass 4m, and a body of mass m leaping with velocity v0 as shown in the attachment towards the opposite side of the square. I have found the new center of mass of the system but do not quite understand why there would be no external torques in action around the bottom left corner. I'd appreciate some insight.
There seems to be no external forces to produce any external torques.
What about gravity, acting downwards from the new center of mass (of the body that has leaped and reached the opposite side of the square and the square)? With respect to the bottom left corner, why won't gravity exercise a torque?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
