Conservation of Energy and Centripetal Motion Question
In summary, the skier leaves the surface of the hill and becomes air-borne at a vertical distance of h=R/3, measured from the top of the hill.
cblack
A skier starts at rest on the top of Mt Circular, a strange, smooth, icy hill shaped like a hemisphere. The hill has a constant radius of R. Neglecting friction (it is icy!), show that the skier will leave the surface of the hill and become air-borne at a vertical distance of h=R/3, measured from the top of the hill.
[tex]\Sigma[/tex]F=mv[tex]^{2}[/tex][tex]/[/tex]r
mg[tex]\Delta[/tex]y=[tex]\frac{1}{2}[/tex]mv[tex]^{2}[/tex]
I have found one question exactly like this one on the forum and I understand that when the skier leaves the hill, the normal force will be 0, but I keep getting R/2 as an answer.
[tex]\Sigma[/tex]F=Fn+mg
0=[tex]\Sigma[/tex]F-mg
0=[tex]\frac{mv^{2}}{R}[/tex]-mg
v=[tex]\sqrt{gR}[/tex]
Substituting this into the conservation of energy equation you get:
mg[tex]\Delta[/tex]y=[tex]\frac{1}{2}[/tex]mgR
[tex]\Delta[/tex]y=[tex]\frac{mgR}{2mg}[/tex]
[tex]\Delta[/tex]y=[tex]\frac{R}{2}[/tex]
Is it reasonable to assume that the skier is in centripetal motion?
The only thig i don't understand is how the skier can have a normal force of zero at any other point than at [tex]\frac{R}{2}[/tex] because at the point the angle between the skier and the vertical will be 90 degrees. If you use the equation [tex]\Sigma[/tex]F=mgcos[tex]\Theta[/tex]+mg where mgcos[tex]\Theta[/tex], which is the noraml force, can only equal 0 at 90 degrees. If the skier is leaving somewhere between 0 and 90 degrees how can this be calculated?
hello cblack, your physical concept is correct. you almost got it. you just left out [tex]\theta[/tex] somewhere it should be.
try to find v in terms of [tex]\theta[/tex] using conservation of E.
then construct equation of motion. Be careful the v here also relates to [tex]\theta[/tex]. then you can solve for [tex]\theta[/tex] :smile:
Realize that the weight acts vertically, not centripetally. (Find the radial components of the forces.)
1. What is the conservation of energy?
The conservation of energy is a physical law that states that energy cannot be created or destroyed, but can only be transformed from one form to another. This means that the total amount of energy in a closed system remains constant over time.
2. How does conservation of energy relate to centripetal motion?
In centripetal motion, an object moves in a circular path due to a centripetal force acting on it. According to the conservation of energy, the total mechanical energy (kinetic energy + potential energy) of the object remains constant as it moves. This means that as the object moves in a circular path, the kinetic energy is constantly changing, but the total energy remains the same.
3. How do you calculate the kinetic energy of an object in centripetal motion?
The kinetic energy of an object in centripetal motion can be calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is the velocity of the object. This formula applies to any object in circular motion, whether it is moving in a horizontal or vertical circle.
4. Does conservation of energy apply to all types of motion?
Yes, the conservation of energy applies to all types of motion. It is a fundamental law of physics that applies to all systems, whether they are in motion or at rest. In any physical process, the total energy of the system remains constant.
5. How does the conservation of energy affect the design of roller coasters?
The conservation of energy plays a crucial role in the design of roller coasters. The designers must ensure that the roller coaster has enough potential energy at the top of each hill to overcome the force of gravity and maintain a constant speed throughout the ride. This requires careful calculations and adjustments to the track design to ensure a thrilling and safe experience for riders.
