Conservation of energy and momentum
The discussion centers on the conservation of energy and momentum in an inelastic collision involving a bullet and a block. It highlights the challenge of finding the final velocity of the bullet after it penetrates the block, noting that the initial approach yielded an incorrect small value for Vf. Participants suggest using the energy required to compress a spring by 5 cm to determine the block's speed post-collision, emphasizing the need for the correct momentum equation. The conversation concludes that the block's speed must be calculated to understand the energy transfer accurately. Overall, the correct application of conservation laws is essential for solving the problem effectively.
Shaun97
this would be considered as an inelastic collision where (m1v1) + (m2v2) = (m1+m2)vf
also the conservation of energy being (∆K +∆U)=0 i tried using the conservation of energy to find v2 as the variable we are looking for is Vf, the speed the bullet leaves the block, and v2 (velocity of the block) is what's missing in the collision equation in order to solve for Vf, although, knowing that the correct answer is 100, these method doesn't the correct answer, it gives a very small value for Vf which doesnt't make sense.
The bullet penetrates the block and goes on through. The block and the bullet have different final velocities. So the equation you give for conservation of momentum cannot be correct.
Try working backward from the 5 cm figure. How much energy must the block have had following the collision to have allowed it to compress the spring by 5 cm?
the energy of the block giving the velocity of the block after the bullet hits it right? but then what collision formula could be used to find the velocity as the bullet leaves
Right, this gives you the velocity of the block after the bullet hits it. Now you just need conservation of momentum. Total momentum before = Total momentum after.
You were almost there in your original post but just used the wrong formula for total momentum after the collision.
But this equation would give (0.5)(m)(v)^2=-(0.5)(k)(x)^2
because Ui=0 and Ki=0 and Uf=1/2kx^2 and Kf=1/2mv^2 , resulting in a negative velocity
No, not right.
After the bullet passes through the block, the block has just enough speed to compress the spring the given amount. Solve for that speed.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
