Conservation of Energy (Kinetic and Potential Energies)
A 5.00-kg block moves up an inclined plane at a 30° angle with an initial speed of 8.00 m/s and comes to rest after 3.00 m. The change in kinetic energy is calculated to be 160 J, while the change in potential energy is 73.5 J, indicating that mechanical energy is not conserved due to friction. The work done by friction is determined to be 86.5 J, leading to a frictional force of approximately 28.8 N. The calculations highlight the relationship between kinetic and potential energy changes and the impact of friction on the system. Understanding these concepts is crucial for solving similar physics problems.
Pappers08
A 5.00-kg block is set into motion up an inclined plane with an initial speed of 8.00 m/s. The block comes to rest after traveling 3.00m along the plane, which is inclined at an angle of 30° to the horizontal. For this motion, find the change in the block's kinetic energy, the change in the block's potential energy, the frictional force exerted on it, and the coefficient of kinetic energy.
W= F*d
PE= mgh
KE= 1/2m(v squared)
Fnet=ma
I haven't attempted it yet, because I'm stuck on how to start it. I missed the day of school we started going over this.
Since the block comes to rest, it looses all of it's kinetic energy. So the change will be equal to the initial kinetic energy mv2/2 .
The change in potential energy is mgΔh , where Δh is the change of height.That would be Δh = 3m sinθ.
When you do the above calculations you will see that the change in kinetic energy is not the same as the changde in potential energy. It looks like mechanical energy is not conserved, but that's because there is friction. The difference between change in kinetic energy and change in potential energy will be the work of friction. Find this difference and, since W = F Δx, the friction's will force will be W/Δx , where Δx = 3m
So according to this, the block's kinetic energy would be 160J...the block's potential energy would be 73.5J...the frictional force would be 86.5N?
86.5 J is the work of friction. The force will be 87.6J/3m = 28.8 N
Okay thanks! That really helps!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
