Conservation of energy problem(s)
The discussion focuses on solving a conservation of energy problem involving a ski sliding down an incline and a roller coaster descending from a height. For the ski, the calculated speed at the base of a 22-degree incline with a friction coefficient of 0.090 is initially found to be 23.4 m/s, but the correct answer is 21 m/s according to the textbook, indicating a potential error in the friction calculation. The second part of the problem involves determining how far the ski travels on a level surface after descending, with some confusion about the kinetic energy equation used. In the roller coaster scenario, the calculated final speed of 29.7 m/s also differs from the textbook answer of 23 m/s, suggesting a mistake in accounting for friction. Overall, the participants are troubleshooting their calculations and discussing unit consistency in their energy equations.
Quincy
A ski starts from rest and slides down a 22o incline 75 m long. a) if the coefficient of friction is 0.090, what is the ski's speed at the base of the incline? b) If the snow is level at the foot of the incline and has the same coefficient of friction, how far will the ski travel along the level? Use energy methods.
-Wnc = (KEf - KEo) + (PEf - PEo)
a)Since the hypotenuse of the incline is 75 m, and the angle relative to the horizontal is 22o, the vertical height is 75 sin22o = 28.1 m.
PEf and KEo cancel out, and the equation becomes:
PEo = KEf + Wnc
That simplifies to:
mgh = (1/2)mv2 + umgcos22o -- (u is coefficient of friction)
masses cancel out
(9.8)(28.1) = (1/2)v2 + (0.09)(9.8)cos22o
v = 23.4 m/s -- According to the book, the answer is 21 m/s. What am I doing wrong??
b) KEf = umg * d?
Possibly the book is implying that when it gets to the bottom of the incline, it is on a horizontal surface, perhaps your final velocity is parallel to the incline?
b) looks ok to me, assuming KEf is the kinetic energy at the base of the incline
Also, how about this:
Suppose a roller coaster 45 m high has a speed of 1.7 m/s. If the average force of friction is equal to one-fifth of its weight, with what speed will it reach the the ground?
Relevant Equations: -Wnc = (KEf - KEo) + (PEf - PEo)
-- PEf cancels out
The equation becomes: (1/2)mvo2 + mgh - mg/5 = (1/2)mvf2
-- masses cancel out
= (1/2)(1.7)2 + (9.8)(45) - (9.8/5) = (1/2)vf2
Vf = 29.7 m/s
-- According to the book, the speed is 23 m/s... What am I doing wrong in this problem?
Just skimming over it, it looks like there's an error with your units in there:
Using that equation (providing the masses hadn't been canceled {although it was fine to cancel them}) your units are: J + J - N = J
(correct me if I've interpreted it wrong).
Yes, the units are wrong, it should be (1/2)mvo2 + mgh - (mg/5 * d) = (1/2)mvf2
- the masses would still cancel out, and the equation would become:
(1/2)(1.7)2 + (9.8)(45) - (9.8/5 * 45) = (1/2)vf2
vf = 26.6 m/s... still not the right answer...
{Bump}
