Conservation of energy problem
To determine the velocity a projectile must have at the center of the Earth to reach the surface, one must consider the gravitational potential inside the Earth, which differs from the potential outside. The initial calculation of 11.8 km/s is incorrect; the correct velocity is 7.9 km/s due to the gravitational force being zero at any point inside the Earth. The gravitational potential energy formula must account for the mass distribution within the Earth, leading to a different potential energy calculation. The negative sign in the gravitational potential energy equation indicates that energy is being released as the projectile moves towards the surface, and it is cancelled out by the conservation of energy principle. Understanding these concepts is crucial for accurately solving the problem.
Airsteve0
I am having trouble with the following problem:
With what velocity should a projectile be started ar the center of the Earth to reach the surface of the Earth?
When I attempt to solve this using 1/2mv^2 = -(GMm)/R I get an answer of 11.8 km/s. However, the correct answer is 7.9km/s. I know that it has something to do with the potential inside the Earth but I don't even know where to start with incorporating that. Also could someone tell me how the negative on the right hand side is cancelled. Thanks a lot!
At any point r < R inside the earth, the net gravitiational force from all the mass from the radius at that point to the surfce (from r to R) cancels out and is zero. I'm assuming you're supposed to figure out the gravitational potential formula for a point r within the Earth (assuming it's a sphere).
It's supposed to be negative, and absent any other forces, given an initial condition (position and velocity), the sum of gravitational potential energy and kinetic energy will be a constant. Note that GPE becomes less negative as R increases.
