Conservation of Energy speed of block
The discussion focuses on calculating the speed of a block sliding down a frictionless track with a rough area. The block's speed upon leaving the track can be determined using the conservation of energy principle, accounting for the loss of gravitational potential energy converted into kinetic energy. Friction affects the block's velocity, as it converts some kinetic energy into heat, necessitating the use of the work-energy theorem to find the work done by friction. The total speed of the block upon hitting the ground can also be calculated using gravitational potential energy. Understanding how to incorporate friction into these calculations is essential for accurate results.
himetx
A block starts at rest and slides down a frictionless track except for a small rough area on a horizontal section of the track (as shown in the figure attached for#007). It leaves the track horizontally, flies through the air, and subsequently strikes the ground. The acceleration of gravity is 9.8 m/s2 .
m=0.405 kg
H=5.2 m
h=2 m
rough area=1.2m
μ=0.3
A. What is the speed v of the block when it leaves the track? Answer in units of m/s.
B. What is the horizontal distance x the block travels in the air? Answer in units of m.
C. What is the total speed of the block when it hits the ground? Answer in units of m/s.
The initial height of the block when it is at rest at the top of frictionless track = H
Height of the point where the block leaves the track horizontally = h
Change in height = H - h
Loss in gravitational potential energy of block=mg(H-h)
Gain in kinetic energy of block as it leaves the track =Loss in gravitational potential energy of block
Gain in kinetic energy =(1/2)mv^2
(1/2)mu^2=mg(H - h)
u = sq rt 2g (H - h)
PART A. The ball leaves the track with a speed = sq rt 2g ( H - h)
If H and h are in meter then ball leaves the track with a speed = sq rt19.62 (H-h) m/s
I understand how to get to this point, but I don't know how to account for the friction that needs to be considered to determine the velocity.
PART C. If V is speed with which block hits the ground.
Final kinetic energy of block (KE) =initial potential energy of block (PE)
(1/2)mV^2=mgH
V= sq rt 2gH
the speed of the block when it hits the ground is sq rt 2gH
If H is in meter then speed is [ sq rt 19.62 H ] m/s
The conservation law of energy states that energy is never created or destroy, only converted.
When there is friction between two objects, there is a loss in kinetic energy, but this energy doesn't disappear. It's converted into heat (and sound, and sometimes other forms of energy. But only heat here).
KE_{1} + PE_{1} = KE_{2} + PE_{2} + E_{h}
Heat energy caused by friction is simply determined by:
E_{h} = F_{f}d = \mu mgd
If that doesn't help, let me know.
I don't think heat energy applies to this problem. We have yet to discuss heat energy in my class. If you can show me how this applies using the values given, that would help me understand what your trying to convey.
welcome to pf!
hi himetx! welcome to pf! :wink:
you can use conservation of energy, but for the rough patch you need to use the work energy theorem: https://www.physicsforums.com/library.php?do=view_item&itemid=75" = change in (mechanical) energy …
so find the work done by https://www.physicsforums.com/library.php?do=view_item&itemid=39", and subtract it from the energy :smile:
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 17 ·
