Conservation of energy with kinetic energy and spring
The discussion revolves around a problem involving two dynamics carts colliding elastically while compressing a spring. The initial kinetic energies of both carts were calculated, leading to a total energy of 54 J before the collision. The participants explored using conservation of momentum and energy to determine the maximum compression of the spring, ultimately finding it to be approximately 3.178 cm. There was some confusion regarding the application of momentum and energy conservation principles, but the calculations were confirmed to be correct. The key takeaway is that at maximum compression, both carts share the same velocity, which is essential for determining the distance of closest approach.
Lolagoeslala
A dynamics cart 1 ahs a mass of 1.8 kg and is moving with a velocity of 4.0 m/s
along a frictionless track. Dynamics cart 2 has a mass of 2.2 kg and is moving at 6.0 m/s
. The carts collide in a head-on elastic collision cushioned by a spring with spring constant k = 8.0 x 104 N/m.
Determine the compression of the spring in cm, during the collision when cart 2 is moving at 4.0m/s
and
Calculate the maximum compression of the spring in cm
so the givens are these:
m1 = 1.8 kg
m2 = 2.2 kg
v1=4 m/s
v2 = 6 m/s
K = 80000N/ma)
Ek = 1/2m2v2`
Ek = 1/2(2.2kg)(4m/s
)^2
Ek = 17.6 J
17.6 J = 1/2kx^2
17.6 J = 1/2(80000N/m)x^2
0.020976176 m = x
b)
I am not sure what to do for this particular part?
v1`=(m1-m2)/(m1+m2)v1 + (m1xm2)/(m1+m2)v2
v1`=0.4 m/s
+5.94 m/s
v1`= 6.34 m/s
v2` = (2m1)/(m1+m2)v1 + (m2-m1)/(m1+m2)v2
v2` = 3.6 m/s
+ 0.6 m/s
v2` = 3 m/s
Ektot = 1/2m1v1^2 + 1/2m2v2^2
Ektot = 14.4 J +39.6 J
Ektot = 54 J
Ektot` = 1/2m1v1`^2 + 1/2m2v2`^2
Ektot` = 36.17604 J + 9.9 J
Ektot` = 46.07604 - but they are not the same since its elastic they are supposed to be the same​
and
m1 = 1.8 kg
m2 = 2.2 kg
v1=4 m/s
v2 = 6 m/s
K = 80000N/m
a)
Ek = 1/2m2v2`
)^2
Ek = 17.6 J
17.6 J = 1/2kx^2
0.020976176 m = x
b)
I am not sure what to do for this particular part?​
For part a), which is incorrect:
What is the KE of cart 1, when cart 2 is moving at 4.0m/s
? You need to include this in your total KE.​
would it be Ek = 1/2m1v1^2
Ek = 1/2(1.8kg)(4m\s)^2
Ek= 14.4 J
so then itll be
Ektot = 14.4 J + 17.6 J
Ektot = 32 J
32 J = 1/2(80000N/m)x^2
0.02828 m = x
how about this?​
Ek= 14.4 J
so then itll be
Ektot = 32 J
0.02828 m = x
how about this?
Incorrect.
Use conservation of momentum to find the velocity of Cart 1, when Cart 2 is moving at 4.0m/s
SammyS said:
Incorrect.
Okay .. but my other tutor said you can't use momentum because the energy is being conserved into the spring not the balls itself...? But if you suggest it i can try it that way...
It would be m1v1 + m2v2 = m1v1` + m2v2`
(1.8 kg)(4 m/s
) + (2.2 kg)(6 m/s
) = (1.8 kg)v1` + (2.2 kg)(4m/s
7.2 kgm/s
+ 13.2kgm\s
= (1.8kg)v1` + 8.8kgm/s
6 kgm/s
- 8.8kgm\s
= (1.8kg)v1`
2.8 kgm\s
/ 1.8 kg = v1`
1.556 m/s
= v1`
Ektot= 1/2m1v1`^2 + 1/2m2v2`^2
Ektot = 2.1790 J + 17.6 J
Ektot = 19.779 J
Ektot = 1/2kx^2
19.779 J / 40000 N/m = x^2
0.022236 m = x​
SammyS said:
Incorrect.
but it doesn't say that the m1 would also be changing in the velocity... then why do we need to find the v1` ?​
... because the velocity of m1 does change! Conservation of momentum tells you that, without it being stated in the problem .
Oh i see what you are talking about ... so how is my part a calculation i just did?
ANY BODY?!:confused:
Patience !
You need to quit prematurely bumping your posts !
(1.8 kg)(4 m/s
) + (2.2 kg)(6 m/s
7.2 kgm/s
+ 13.2kgm\s
6 kgm/s
- 8.8kgm\s
= (1.8kg)v1`
2.8 kgm\s
/ 1.8 kg = v1`
1.556 m/s
= v1`
Ektot = 19.779 J
Ektot = 1/2kx^2   This is the Potential Energy of the spring.
0.022236 m = x​
Why are you equating the Potential Energy of the spring to the total KE of the two carts?​
Well the amount of energy that the carts have would be transferring into the spring wouldn't it?
Well when i come to think of it...
Ektot = 19.779 J is the kinetic energy when they have come together compressing the spring..
but how much did they have the initial energy...
To do this i did this:
Ektot(initial) = 1/2m1v1^2 + 1/2m2v2^2
14.4 J + 39.6 J = 54 J
And if i subtract the 54 J - 19.779 J = 34.221 that's the energy lost in the spring correct?
so then i can use that ...
34.221 J = 1/2(80000N/m)x^2
0.029249 m = x
The amount of (kinetic) energy the carts lose will be transferred to PE of the spring. The Total energy is conserved.
Yes that is correct similarely what i have done like this..
0.029249 m = x
im i correct on this calculation?
And if i subtract the 54 J - 19.779 J = 34.221 that's the energy [STRIKE]lost[/STRIKE] in the spring correct?
0.029249 m = x
I'm i correct on this calculation?
Yes. now convert that to cm.
Okay but now what about the the sexond part where you need to find the maximum spring compression ? i showed my work above... but the energy before and after is different.. is that the way u should do it?
m1 = 1.8 kg  m2 = 2.2 kg  v1=4 m/s
  v2 = 6 m/s
  K = 80000N/m
b)
v1`=0.4 m/s
+5.94 m/s
v1`= 6.34 m/s
v2` = 3.6 m/s
+ 0.6 m/s
v2` = 3 m/s
Ektot = 54 J
Where did you get those equations for v1' & v2'? For what conditions are those equations true? I suspect that they're for the velocities resulting from an elastic collision. As you point out, there's something wrong because there is kinetic energy lost.
While you have an error somewhere when you used these. They have nothing to do with solving part b).
At the instant the spring is at maximum compression, the two carts have the same velocity, v1 = v2 . Why is that the case?​
well those equations are true for two moving object.. and i found the mistake where i was wrong... for the v1` . the second mart is (2m1/m1+m2)v2
i used these to find the kinetic energy i just wanted to see if they equal the kinetic energy before and after.. and its true... so now to find the maximum compression.. i need to find the velocity of them in the middle... right?
Lolagoeslala said:
well those equations are true for two moving object.. and i found the mistake where i was wrong... for the v1` . the second mart is (2m1/(m1+m2))v2
In the middle of what ?
Use conservation of momentum to find v2 & v2, when they're equal. Of course that's when v1 = v2 = vcenter of mass. And, I asked earlier, if you know why that gives the distance of closest approach.
Use conservation of momentum to find v2 & v2, when they're equal. Of course that's when v2 v2 = vcenter of mass. And, I asked earlier, if you know why that gives the distance of closest approach.
Alright this is what i did...
m1v1 + m2v2 = (m1+m2) Vmin
(1.8kg)(4m/s
) + (2.2kg)(6m/s
) = ( 4kg ) Vmin
7.2 kgm/s
+13.2kgm/s
/4kg = vmin
1.5 m\s
= Vmin
Ekmin = 1/2m1Vmin^2 + 1/2m1Vmin^2
Ekmin = 1/2(1.8kg)(1.5m\s)^2 + 1/2(2.2kg)(1.5m\s)^2
Ekmin=2.025 J + 2.475 J
Ekmin = 4.5 J
Ektot - Wdef = Ekmin
54 J - Wdef = 4.5 J
Wdef = 49.5 J
Ekspring = 1/2kx^2
Ekspring = 1/2(80000N/m)x^2
49.5 J/40000N/m = x^2
0.035178 m =x
3.178 cm = x​
Why is it that when v1 = v2, then the spring is at maximum compression. In other words, How is it that you know that this is the condition for which the carts are at a minimum distance from each other?
Well we did a long prove question in class. and that i found out.. but like in general just think about it .. if the spring is connected to both of them.. then the velocity have to be the same inorder and the distance have to be short inorder to cause the maximum compression of the spring but are my calculation correct u would say?
They look fine to me.
