Conservation of Linear momentum and Kinetic energy
The discussion focuses on the conservation of linear momentum and kinetic energy in a system with two masses attached by a string, where one mass is removed at the equilibrium position. The initial kinetic energy is derived from both masses, but confusion arises when one mass is removed, leading to questions about the source of "extra" energy in the system. Participants clarify that conservation laws apply only to closed systems, and removing a mass alters the conditions, preventing the use of these laws. The importance of defining the scenario accurately is emphasized, as misunderstandings about the system's setup can lead to incorrect conclusions. Ultimately, the conversation highlights the necessity of maintaining a closed system to apply conservation principles effectively.
eonden
Suppose that we are working with a horizontal string with two masses attached. There is no friction on the floor and we move those two attached masses away from the equilibrium position by an undefined distance.
Once the string with those two attached masses passes through the equilibrium possition, we remove one of the attached masses.
As there are no forces present in that moment (as we are in the equilibrium position), we should apply the conservation of the linear momentum such that:
(m1 + m2 ) * v_slow = m1 *v_fast (as we remove the m2 with no speed)
So, we move from an initial Kinetic energy = ((m1+m2)*v_slow^2)/2
To a final Kinetic energy = (m1*v_fast^2)/2 from which we can derive using the conservation of the linear momentum --> ((m1+m2)^2 * v_slow^2)/(2*m1) and as ((m1+m2)^2)/m1 > (m1+m2), we have essentialy given energy to the system.
Can someone explain me where does this "extra" energy come from?
Thanks
What do you mean by "equilibrium position"? Please define the scenario you have in mind more completely.
https://ecourses.ou.edu/ebook/dynamics/ch10/sec101/media/d0121.gif
We start from an original position and move the masses away from the origin to the maximum amplitude of the Simple Harmonic Motion. Once we get to that position, we let it contract by the spring force.
Sorry for not including a simple diagram with the doubt.
If I understand you correctly, you want to remove part of the moving mass from the system at some point?
If so, then you can't use conservation laws - these work only for close systems.
In other words, if you magically remove one of the masses, the other one will not change velocity.
I see one mass attached to a wall by a spring. Your first post mentions two masses attached by a string. Are you changing the scenario?
You pull the mass from the equilibrium position and let it go. So what? (I don't see what this has to do with conservation of momentum.)
Please restate your question with reference to the diagram.
Thanks, completely forgot that when talking about closed systems no matter can be exchanged.
Sorry for the stupid question.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
