Conservation of Linear Momentum (spring)
A mass 3M collides with a spring system, and the problem involves determining the maximum compression of the spring using conservation of linear momentum and energy principles. The initial momentum is calculated, leading to a final velocity of 3/4 v0 for the combined mass after the collision. The discussion highlights the importance of correctly accounting for kinetic energy at maximum compression, where not all kinetic energy is converted to elastic potential energy. An alternative approach suggests using the center of mass frame to analyze the system's energy dynamics more effectively. The final answer for maximum compression should be x = √(9Mv0²/20k), correcting the initial calculation.
songsteel
A mass 3M moving horizontally with velocity v_{0} on a frictionless surface, strikes head-on and sticks to a horizontal spring system of natural length l and spring constant k with masses M at each end. The spring has negligible mass.
Determine the maximum compression of the spring.
Conservation of Linear Momentum:
Initial Linear Momentum = Final Linear Momentum
Conservation of Energy:
Initial Kinetic Energy + Initial Elastic Potential Energy = Final Kinetic Energy + Final Elastic Potential Energy
3Mv_{0} = (3M + M)Vfinal
Vfinal = \frac{3}{4}v_{0}
At Maximum compression: all the Kinetic Energy would have been converted to Elastic Potential Energy; let x be the maximum compression.
\frac{1}{2}(4M)(\frac{3}{4}v_{0})^{2} = \frac{1}{2}(k)(x)^{2}
\frac{9}{8}Mv_{0}^{2} = \frac{kx^{2}}{2}
x = √(\frac{9Mv_{0}^{2}}{4k})
According to the answersheet I was given, the final answer should be x = √(\frac{9Mv_{0}^{2}}{20k}) instead.
Would really appreciate it if anyone could help me out. Thanks!
Your assumption that at max compression KE = 0 has no basis. In fact, it is not compatible with conservation of momentum.
I see, would it be correct to write
\frac{1}{2}(4M)(\frac{3}{4}v_{0})^{2} = \frac{1}{2}(k)(x)^{2} + \frac{1}{2}(5M)(V1^{2})
If it is then what method should I use to find v1?
The latter equation is meaningless, because 5M is the mass of the entire system, but V1, even if it was the velocity of the center of mass, is not the only contribution to kinetic energy.
Perhaps the easiest approach here would to use the center of mass frame. Find its velocity. Find the kinetic energy of the center of mass. Then, the internal energy in the center of mass frame is the original energy minus the center of mass energy. In the center of mass frame, the system undergoes simple harmonic motion, whose energy is known.
I think I got it. Thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
