Conservation of Momentum and Collisions
The discussion revolves around calculating the total momentum of a lorry and a car involved in a collision. The lorry has a mass of 20,000 kg traveling at 20 m/s, while the car has a mass of 900 kg traveling at 30 m/s. Initial calculations mistakenly reported the lorry's momentum as 40,000 kg·m/s instead of the correct 400,000 kg·m/s. After correcting the math, the total momentum is determined to be 373,000 kg·m/s, but the direction of the momentum is also significant, as it varies based on the relative positions of the vehicles. The discussion emphasizes the importance of accurate calculations and the vector nature of momentum in collision scenarios.
Charles W
A lorry of mass 20,000kg is traveling at 20.0 metres per second. A car of mass 900kg is traveling at 30.0 metres per second towards the lorry.
What is the magnitude of the total momentum?
1. 209 kNs
2. 373 kNs
3. 427 kNs
4. 1045 kNs
2. Homework Equations
Linear Momentum = Mass * Velocity
I have tried to find the momentum of each object:
20, 000 * 20 = 40, 000 (for the lorry)
900 * 30 = 27, 000 (for the car)
UPDATE
Can't believe I made such a stupid mistake:
20, 000 * 20 = 400,000
Therefore: 400, 000 - 27, 000 = 373, 000 (Option 2)
Momentum is a vector quantity.
I am aware of that, but how does it help to solve this problem?
Check your math (or calculator).
That would probably be it - I can't believe I made such a stupid mistake. I'll edit my original question
I think you missed one zero
By the way my apologies, I didn't see you used a minus sign.
No worries! Thanks for your help :)
Also note that, as stated, there is not one definite answer. It depends on whether the car is in front of or behind the lorry, since these would imply different directions for "towards the lorry".
Likes Charles W and Vatsal Sanjay
