Conservation of momentum astronaut problem
An astronaut with a propulsion unit ejects gas at +30.9 m/s, resulting in a recoil velocity of -0.265 m/s. The astronaut's initial mass is 143 kg, and after gas ejection, it increases to 167 kg. Using the conservation of momentum, the equation needs correction to distinguish between the remaining gas and the expelled gas. The correct approach involves identifying the mass of gas left in the unit to determine the percentage of gas depleted. This problem illustrates the application of momentum conservation in a closed system.
pureouchies4717
An astronaut in his space suit and with a propulsion unit (empty of its gas propellant) strapped to his back has a mass of 143 kg. During a space-walk, the unit, which has been filled with propellant gas, ejects some gas with a velocity of +30.9 m/s. As a result, the astronaut recoils with a velocity of -0.265 m/s. After the gas is ejected, the mass of the astronaut (now wearing a partially empty propulsion unit) is 167 kg. What percentage of the gas propellant in the completely filled propulsion unit was depleted?
p=mv
-.265(astronaut + gas) = 30.9 (gas)
-.265(143 + x) = 30.9x
-37.846 -.265x = 30.9x
31.165x = -37.846
x = 1.214 kg
i don't really know where to go from here... can someone please help?
You need to distinguish between the portion of gas left in the propulsion unit and the portion of gas expelled. You should be able to immediately figure out the portion in the container from the data given. Use the conservation of momentum equation to find the portion expelled.
Correct this equation. The "gas" on the left is the portion left in the unit, which should not be an unknown. And get rid of that minus sign on the left.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
