Conservation of Momentum in Collisions
  • Thread starter Thread starter speckledot
    Momentum
To solve the problem of two colliding balls on a ramp, start by calculating the velocity of the 0.75 kg ball just before the collision using energy conservation principles, considering it rolls down without friction. After determining this velocity, apply the conservation of momentum to find the velocity of the second ball (0.51 kg) after the collision, using its known range of 4.12 m. The collision type can be identified by checking if kinetic energy is conserved; if not, it is inelastic. Understanding projectile motion will help in calculating the range of the first ball after it leaves the ramp. A step-by-step approach is encouraged to grasp the underlying concepts fully.
speckledot
I'm not quite sure how to even start this question >-<
But here it is: A ball with a mass of 0.75 kg initially at rest is placed at the top of curved ramp and allowed to roll down the ramp. It collides with a second ball with a mass of 0.51 kg at the bottom of the ramp which is also initially at rest. The two balls fly off the end of the ramp and land on the floor as indicated on the diagram below. Determine the range of the 0.75kg ball after it leaves the ramp if the range of the 0.51 kg ball is 4.12m. Also determine if this is and elastic or inelastic collision.
I understand that momentum is conserved and that i have to find the time for the vertical displacement at the end, but i don't know what to do with the rest of the info i get.
Hint: Consider conservation of energy for the mass 0.75 kg, and recall projectile motion.
i need help with this question as well. the hint doesn't do anything :(
first you must find the velocity of ball 1 when it collides with the 2. Remember that if it rolls down, it has angular and linear momentum but the work of frictional force is 0(otherwise more data would be required).
Than, you can use linear moment conservation to work out the collision part(as the range of the second ball gives you the velocity after colliding.
hope this hint helps...xD
if there is no friction, may i just use Vf^2 = Vi^2 + 2ad to find the velocity when it hits the ball ?
also, to find the range, i can't seem to figure out which formula would determine that.
i know conservation of momentum is m1v1 = m2v2
thanks for all the help. :)
well, use the parametric equations for the m2...is just a projectile with horizontal movement, you know the final position, the inicial position, the aceleration, you can compute inicial velocity...than, you got v2, m2 and m1, so you can get v1 to see if it is equal to the one you got in the energy conservation equation of m1 rolling down...
could someone please guide me through this homework question, it just seems really complicated. if someone has time.. a step by step would be great..
i want to learn how to do it. (not just some numbers)
thanks
