Conservation of Momentum problem
The discussion revolves around a conservation of momentum problem involving a tennis player returning a shot. The player receives a ball weighing 0.0600 kg traveling at 54.0 m/s and returns it at 34.0 m/s in the opposite direction. The impulse delivered to the ball was calculated as 5.28 kg·m/s based on the change in momentum. For the work done by the racquet, the initial approach using kinetic energy was incorrect, leading to a suggestion to calculate the change in kinetic energy instead. The conversation emphasizes understanding impulse and kinetic energy in the context of momentum conservation.
Sheneron
[SOLVED] Conservation of Momentum problem
A tennis player receives a shot with the ball (0.0600 kg) traveling horizontally at 54.0 m/s and returns the shot with the ball traveling horizontally at 34.0 m/s in the opposite direction. (Assume the initial direction of the ball is in the -x direction.)
(a) What is the impulse delivered to the ball by the racquet?
(b) What work does the racquet do on the ball?
I got part A by finding the change in initial and final momentum of the ball (5.28).
I thought I could get part B by: mv = 5.28 so v = 88 m/s; and plug that into .5mv^2 to find the energy. That was wrong though and now I am not sure how to solve it.
Find the change in kinetic energy.
Ok thanks for the help. Makes sense.
