Conservation of motion and basketball shot
A basketball with a mass of 0.624 kg is shot from a height of 1.55 m at a speed of 12.1 m/s, and it enters the hoop at a height of 3.05 m. The correct formula for calculating the speed just before entering the hoop is v=√(v0^2 + 2g(y0 - y)). A participant initially calculated the speed as 13.26 m/s, which was incorrect due to miscalculating the energy conservation principle. The correct approach involves ensuring the final speed is less than the initial speed of 12.1 m/s, as the ball loses energy while rising. The discussion emphasizes careful calculation and understanding of energy conservation in projectile motion.
xdctassonx
A basketball of mass 0.624 kg is shot from a vertical height of 1.55 m and at a speed of 12.1 m/s. After reaching its maximum height, the ball moves into the hoop on its downward path, at 3.05 m above the ground. Using the principle of energy conservation, determine how fast the ball is moving just before it enters the hoop.
v=√(v0^2+2g(y0-y))
I've tried plugging the numbers in an I come up with an answer of 13.26 m/s. However this is incorrect. I believe I might be thinking of where the ball is being shot from differently.
v=√((12.1^2)+2(9.81)(1.55-3.05)
Any help would be appreciated. Thanks, Dominic.
v=√(v0^2+2g(y0-y))
It looks like you have the formula correct, and you have put the numbers in correctly, but you must have made a mistake doing the calculation. You are taking the 12.1^2, adding a negative number, then taking the square root, so the answer needs to come out less than 12.1 m/s. Check the calculation again.
Got thanks! I actually just calculated the balls maximum height and then treated it as a free fall problem.
Glad to help. Don't forget the Thanks button!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
