What is a Conservative System in Classical Mechanics?
  • Thread starter Thread starter fortaq
    System
A conservative system in classical mechanics is characterized by the total energy remaining constant, which aligns with option b) from the initial query. However, the discussion raises the distinction between conservative systems and closed or isolated systems, suggesting that while a conservative system maintains total energy, it may not necessarily be isolated. The conversation also questions whether a conservative system implies that all forces acting within it are conservative, which would support option a). Ultimately, the definitions and relationships between these concepts remain nuanced and require careful consideration. Understanding these distinctions is crucial for a comprehensive grasp of classical mechanics.
fortaq
Hello,
Could someone tell me what a conservative system in classical mechanics is? Is it
a) a system in that each particle's total energy is constant
OR
b) a system whose total energy is constant, but the individual particles' total energies may change.
THX, fortaq
the answer is b)
Conservative in terms of what?
If it's in terms of matter, then it's a 'closed' system.
If its matter and energy it's an 'isolated' system.
In terms of matter and energy.
But is a conservative system in fact identical with an isolated one?
To add to my initial question:
Is a conservative system not a system in that all forces are conservative? In that case, namely, answer a) should be true.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
