Constant acceleration car problem
The problem involves calculating whether a speeding car will collide with another vehicle moving at a legal speed after the driver slams on the brakes. The initial speeds are 85 km/h for the faster car and 60 km/h for the slower car, with the faster car decelerating at 4.2 m/s². To determine if a collision occurs, one must use the kinematic equation for both cars, substituting their respective initial positions, speeds, and accelerations. The time until the faster car reaches the slower car's speed will indicate if a collision happens or the distance at closest approach. Solving these equations will clarify the outcome of the scenario.
acg7160
You're speeding at 85 km/h when you notice that you're only 10m behind the car in front of you, which is moving at the legal speed limit of 60 km/h. You slam on your brakes, and your car decelerates at 4.2 m/s^2. Assuming the car in front of you continues at constant speed, will you collide? if so, at what relative speed? if not what will the distance between the cars at their closest approach?
I know I have to use x=x0+v0t+(1/2)at^2 but I am not sure exactly what numbers go where.
For car 1 I think x0=0 ; v0=85 km/h (converting to m/s=23.6) and a=-4.2 (decelerating) and for car 2 x0=10 ; v0=60 km/h or 16.67 m/s and a=0? so do i plug those into two separate equations of my x equation in the relevant equations part and then solve for t? and then does t show if they collide or not?
I am not good at physics and need help please!
Please help!
I think I'd start by calculating how long it takes in time for the faster car to slow to the speed of the slower car, and then figure out what their positions are at that time. That will tell you if they hit or not. Then I would go on with the rest of the problem.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
