Constant acceleration motion problem,
An arrow is shot upward at 25 m/s, followed by a second arrow shot 2 seconds later at the same speed, both experiencing a downward acceleration of 9.8 m/s². The equations of motion for both arrows were set up, but the initial misunderstanding involved the timing of the arrows. The first arrow's time of flight was calculated incorrectly as 1.55 seconds, which only accounted for the second arrow's launch. The correct time for the arrows to meet from the first arrow's launch is 3.55 seconds, after adding the 2-second delay for the second arrow. Clear communication of the problem-solving steps facilitated understanding and resolution of the confusion.
chroncile
An arrow is shot vertically upward with an initial speed of 25 m/s. Two seconds later, another arrow is shot upward with the same speed. On its way up, the second arrow meets the first arrow on its way down. Assume that both arrows experience a constant downward acceleration of 9.8 m/s2.
How long does it take (from the time the first arrow is shot) for the arrows to meet?
d = vf * t - 0.5(a)(t)2
tA1 = tA2 + 2
dA1 = 25t - 4.9t2
dA2 = 25t - 4.9t2
Since dA1 = dA2
25tA1 - 4.9tA12 = 25tA2 - 4.9tA22
Since tA1 = tA2 + 2
25(tA2 + 2) - 4.9(tA2 + 2)2 = 25tA2 - 4.9tA22
19.6t = 50-19.6
t = 1.55 s
The correct answer is 3.55 s
tA1 = tA2 + 2
dA1 = 25t - 4.9t2
dA2 = 25t - 4.9t2
Since dA1 = dA2
Since tA1 = tA2 + 2
19.6t = 50-19.6
t = 1.55 s
I believe it's just that you have this equation off: tA1 = tA2 + 2
The 2nd arrow is shot 2 seconds after the first, not the other way around. Does that fix it?
Actually, the only error is related to that equation. You forgot to add the 2 seconds to the time of the 2nd arrow being shot. You solved tor t2, and they asked for t1.
I tried switching them around, but I still ended up with 1.55 s, help?
Did you see my last post about adding the 2 seconds?
Can you please explain that?
The solution you got is for the time from firing the 2nd arrow up. But you fired the 1st arrow 2 seconds earlier. Therefore the time for the arrows to meet from the time you fired the first arrow is 1.55s + 2.0s = 3.55s.
Okay, I get it now, thanks :smile:
You're welcome. You did a good job setting up and solving the problem. It makes it a lot easier to help when we get to see all of your work like that.
