Constant acceleration of hockey puck
A hockey puck sliding on a frozen lake comes to rest after traveling 249 m with an initial velocity of 4.5 m/s. To find the constant acceleration, the equation v² = u² + 2ad is used, where v is the final velocity (0 m/s) and u is the initial velocity (4.5 m/s). By substituting these values, the calculation shows that the acceleration is approximately 0.0407 m/s². The discussion emphasizes the importance of using the correct equations that incorporate initial and final velocities along with displacement. This approach effectively resolves the problem of finding acceleration.
anna_chem
A hockey puck sliding on a frozen lake comes to rest after traveling 249 m. If its initial velocity is 4.5 m/s, what is its acceleration if that acceleration is assumed constant?
V(t)= v(initial) + at
d= v(initial)*t + .5at^2
V(t)= 4.5 m/s + at or 249 m= 4.5 m/s*t + at^2
I'm confused as to where to go from here. How can I go about finding t, so that I can find a? Or am I trying to go about it wrong?
Yes, that is one way, but you are missing time, so that equation can't be used.
We need an equation with initial,final velocity,displacement and acceleration
like this one
v2=u2+2ad
Thanks for the quick response. So, given that initial velocity is 4.5 m/s and final velocity is 0, then:
4.5^2=0+498a thus a=.0407 m/s^2
Does that look correct?
v2=u2+2ad
v=final velocity
u=initial velocity.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
