Constant Angular Acceleration Question
The problem involves a salad spinner that undergoes constant angular acceleration as it slows down after spinning. The original poster seeks to determine the angular distance traveled while coming to rest and the angular acceleration during this deceleration.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster calculates initial angular velocity based on the number of revolutions and time, and attempts to find angular distance and acceleration using relevant equations. Other participants suggest methods for finding final angular velocity and provide equations for angular motion.
The discussion includes attempts to verify calculations and explore different equations related to angular motion. Some participants provide guidance on how to approach the problem, while others seek clarification on specific aspects of the calculations.
Participants are working within the constraints of homework rules, focusing on understanding the relationships between angular displacement, velocity, and acceleration without providing complete solutions.
Paymemoney
Dario, a prep cook at an Italian restaurant, spins a salad spinner 20.0 times in 5.00 seconds and then stops spinning it. The salad spinner rotates 6.00 more times before it comes to rest. Assume that the spinner slows down with constant angular acceleration.
a) Find the angular distance the salad spinner travels as it comes to rest
b) What is the angular acceleration of the salad spinner as it slows down?
constant rotational equations
a) ok, i found initially when the spinner is spinning 20 times in 5seconds to have a angular velocity of 1440 degrees. For the second part when it spins 6 more times, i calculated: \frac{6 * 360}{5}
so angular distance is 1440-432 = 1008 degrees
b) To find angular acceleration i used the formula : \omega final^2 = \omega initial^2 + 2\alpha\theta
432^2 = 1440^2 + 2\alpha * 1008
\alpha = \frac{186624 - 2073600}{2016}
\alpha = 936 rad/s^2
Can someone please check if this is correct.
P.S
The angular velocity is equal to the change in theta divided by the change in time. You know that there is 20 revolutions on 5 seconds. Angular velocity is measured in radians per second so you must multiply 20(2pi) then divide by the time interval of 5 seconds. This will give you your initial angular velocity.
how would i find my final angular velocity?
You can use the equation of change in theta is equal to (1/2)(wfinal+winitial) times the change in time. Since we know the data at the initial point we can plug in the numbers which would be 20(2pi)=(1/2)(wfinal+[(20*2pi)/5])(5) then solve for wfinal
thanks i got the answer
10K
  • · Replies 20 ·
  • · Replies 19 ·
