Construct a 2 by 3 system that has these particular and homogeneous eq
s3a
Construct a 2 by 3 system Ax = b with particular solution xp = (2,4,0) and homogeneous solution xn = any multiple of (1,1,1).
The answer is {{1,0,-1},{0,1,-1}} x = {{2},{4}} which has xp and xnull = (c,c,c).
Ax = b
I tried putting (2,4,0) as row 1 and (1,1,1) as row 2 and then reducing, I get {{1,0,2},{0,1,-1}} but, that doesn't seem to match up with the answer.
Could someone please tell me how to do such a problem?
Any input would be greatly appreciated!
Similar to solving those problems, it is useful to begin with the homogeneous solution. The particular solution can be added afterwards.
The answer is
One possible answer.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
