I Constructing a vector from a point
  • I
  • Thread starter Thread starter Mr Davis 97
    Point Vector
Mr Davis 97
So I have solved the following problem: Consider two points located at ##\vec{r}_1## and ##\vec{r}_2##, separated by distance ##r = |\vec{r}_1 - \vec{r}_2|##. Find a vector ##\vec{A}## from the origin to a point on the line between ##\vec{r}_1## and at ##\vec{r}_2## at a distance ##xr## from the point at ##\vec{r}_1## where ##x## is some number.
So I have solved this problem. The answer is ##\vec{A} = (1 - x) \vec{r}_1 + x \vec{r}_2##. I did this by allowing ##\vec{r}## to vary with ##x##, and then ##\vec{A}## was just the vector sum of ##\vec{r}_1## and ##x \vec{r}##. However, I am not really understanding the solution. When we substitute 0 for x, we find that we get ##\vec{A} = \vec{r}_1##, as expected. However, when we substitute r for x, we don't get ##\vec{r}_2##. What is going on here?
Mathematics news on Phys.org
##A = r_2## when ##x = 1##. The question says "at a distance ##xr## from ##r_1##", so when ##x=1## you are distance r from ##r_1## which is ##r_2##.
Oh wow, that is pretty obvious now. Thanks!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
