Continuety of sum of functions
  • Thread starter Thread starter transgalactic
    Functions Sum
transgalactic
A.does f(x) +g(x) continues in X0 when
f(x) continues in X0 but g(x) doesnt?
B.does f(x) +g(x) continues in X0 when both
f(x) and g(x) are not continues in X0?
prove and give exmple to support your answer
If you're uncertain whether or not each function is continuous, try to constuct a counter example satisying the initial premises. After that, prove whatever result you obtained.
For b) consider functions that have discont. but for example sum to be some constant.
i don't know how to prove such things
Are you sure you are supposed to prove them? b) is false using the example I gave so come up with a counterexample using the logic that I told you
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
