Why Does the Continuity of \( f(x) = x^m \sin(1/x) \) Fail at Zero?
  • Thread starter Thread starter transgalactic
    Parameter
Hi,
Re: part A: I think this is a "setup" to make you think the answer is easy. Yes, it appears that: for m =1,2,3,4 ... etc, the function is continuous at x=0. Your logic looks good to me.
However, the sin(1/x) function oscillates infinitely fast as x --> 0, so I think you'll find the answers to B and C to be surprising.
how to solve it?
Can you differentiate f(x) "formally" ? I get this:
f'(x)= mxm-1sin(1/x) + xm-1cos(1/x)(-1)x-2
For the case of m=1, I get:
f'(x) = sin(1/x) - cos(1/x)/x2
The first term doesn't approach anything as x--> 0. It oscillates infinitely fast between +1 and -1. No limit, therefore not continuous.
Also, in second term, cos(1/x) -->1, but 1/x2 --> infinity, so again no limit.
Your assignment, Mr. Phelps, should you choose to accept it ... :) ... is to find an m > 0 where f'(0) is continuous. See if you can find one.
i got a solution to A
and it says
some thing about
if m=0 then
<br /> <br /> x_n = \frac{1}{(2n)\pi} <br />
i don't know how they came up with this Xn
and what i need to do with it
Hello,
Oops, I missed the m > OR = 0 part.
For f(x) = xmsin(1/x)
If m=0, then f(x) = sin(1/x)
So, for m=0, your logic for testing continuity of f(x) at zero breaks down. Sin(1/x) is not continuous at 0.
Now, regarding that "solution" you found that says:
Hmm. Well, let's look at when sin(1/x) = 0
then 1/x = {\pi, 2\pi, 3\pi, ... } = n \pi
So I get: x = \frac{1}{(n)\pi}
Different than your solution, but the same idea: as n gets larger, x gets closer to 0, but ... between every point where sin(1/x) = 0, it oscillates up to +1 (or down to -1):
when sin(1/x) = 1 --> 1/x = {\pi/2, 2\pi+\pi/2, ...} = 2n\pi+\pi/2 --> x = \frac{1}{(2n\pi + \pi/2)}
and when sin(1/x) = -1 --> 1/x = {3\pi/2, 2\pi+3\pi/2, ...} = 2n\pi+3\pi/2 --> x = \frac{1}{(2n\pi + 3\pi/2)}
So ... as x ->0, it passes through a full oscillation between each successive x_n = \frac{1}{(2n)\pi}, taking on values 0, 1, 0, -1, 0 successively between xn and xn+1
That's a long-winded answer. Does it help?
Regards, BobM
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
