Continuity Equation: Relationship between vA and vB in terms of d and D
The continuity equation relates the velocities vA and vB to the diameters d and D of two cross-sections in a fluid flow. The user confirms that d and D represent different diameters and clarifies that the equation involves density, cross-sectional area, and velocity. They initially attempt to calculate the ratio of speeds using the areas derived from the diameters but realize a mistake in their calculations. Upon reevaluation, they successfully determine the correct relationship between the speeds. The discussion highlights the importance of correctly applying the continuity equation for fluid dynamics problems.
bcalkins
The continuity equation provides a second relation between the vA and vB, this time in terms of the diameters d and D. Numerical check: If the diameters are d = 1 cm and D = 10 cm, what is the ratio of the speeds, vB/vA?
To clarify, is both d and D diameters, just one's capitalized to show the difference between the two?
The continuity equation is: Δm=ρV=ρAvΔt
my notes show: ρ2A2v2 = ρ1A1v1
Am I reading correctly that:
ρ=density
A= cross-sectional area (equal to ∏(Diameter^2/4))?
v= velocity/speed
A1v1=A2v2 ===> v2=v1(A1/A2) ====> v2=v1(d1^2/d2^2) ===>
Plugging this into the above given information:
v2= v1(10cm^2/1cm^2) = v1(100cm)
v1 = v2 (1cm^2/10cm^2) = v2(.01cm)
So the ratio of speeds would be .01cm/100cm = .0001
I know I'm doing something wrong, but this is all I have in my notes that looks somewhat useable. Please help! Thank you!
Wow, after typing that all out I was seeing what I was doing wrong. I've got it figured out now. :)
