Continuity of the first Maxwell equation.
The discussion centers on proving the continuity of the first Maxwell equation, specifically regarding the divergence of the electric field, div(∇E) = (1/ε₀)ρ. The proof involves integrating both sides and relating the electric field to charge. A participant points out the ambiguity in defining the "y" direction, suggesting that only the parallel component of the electric field is continuous. After clarification that the y component is defined as parallel to the surface, the original poster seeks confirmation on the validity of the proof. The conversation emphasizes the importance of clear definitions in mathematical proofs.
Bert
Suppose that we will proof the continuity of the first maxwell equation:
So we have div(\vec{E})=\frac{1}{\epsilon _0} \rho than \iiint \ div(\vec{E}) = \oint_v \vec{E} d\vec{s}=\iiint \frac{1}{\epsilon _0 } \rho
than follewed E_{y1} l -E_{y2}l=Q
Therefore E must continue is this a good proof? Thanks.
You have not defined what "y" direction is. So your y components are ambiguous.
Only the parallel component of the E-field (parallel to the surface) is continuous.
Zz.
Thanks if I define my y component as the parallel one. Is than the proof oké?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
