Continuous Functions of One Random Variable
4 replies · 2K views · last reply
SpiffWilkie
My problem is as follows (sorry, but the tags were giving me issues. I tried to make it as readable as possible):
Let X have the pdf f(x)= θ * e-θx, 0 < x < ∞
Find pdf of Y = ex
I've gone about this the way I normally do for these problems.
I have
G(y) = P(X < ln y) = ∫ θ * e-θx dx from 0 to ln y = 1 - y-θ
So then I need g(y) = G'(y) of Y? which would be
θ * e-θln y?
I know there's something obvious in there that I'm missing. I'm having a hard time connecting the last equation to the process that I usually follow.
If anyone can give a nudge, I'd be grateful.
Find pdf of Y = exI've gone about this the way I normally do for these problems.
I have
G(y) = P(X < ln y) = ∫ θ * e-θx dx from 0 to ln y = 1 - y-θSo then I need g(y) = G'(y) of Y? which would be
θ * e-θln y?
Have you taken the derivative of the expression 1-y-θ with respect to y, rather than writing y-θ in exponential form? That will give you your probability density for y. You have a slight mistake in your first attempt θe-θln y - this can be rewritten as θ y-θ; can you spot what the problem is and how it can be fixed?
As in (θy-θ)/y ?
As for that, am I missing 1/y, so I get (θ y-θ)/y ?
Sorry if I'm not grabbing onto what your trying to say. The more I think about it the muddier I get.
SpiffWilkie said:
As in (θy-θ)/y ?
You did not make an error; the result you had --- P(Y < y) = 1 - y^(-θ) --- is correct exactly as written. However, you need to specify the interval {y ≥ 1}, because y = exp(x) ≥ 1 for x ≥ 0. In other words, P{Y < y} = 0 for y < 1.
RGV
RGV
Big, fat facepalm going on over here...
That's why I was so unsure of what I was getting. I was trying to integrate from 0 to infinity to check the PDF, which wasn't giving me 1.
Stupid interval...
Anyhow, thank you very much for the explanation. It helped out a lot. Off to practice some more problems...
