Contraction in the Riemann Tensor
Fraser
Hi all,
I'm trying to follow through some of my notes of a GR course. The notes are working towards a specific expression and the following line appears:
R^{\alpha \beta}_{\gamma \delta ; \mu} + R^{\alpha \beta}_{\delta \mu ; \gamma} + R^{\alpha \beta}_{\mu \gamma ; \delta}=0
Which by contraction over \alpha and \gamma becomes
R^{\alpha \beta}_{\alpha\delta ; \mu} + R^{\alpha \beta}_{\delta \mu ; \alpha} + R^{\alpha \beta}_{\mu \alpha; \delta}=0
I'm afraid I don't understand this, it seems to relabel \gamma with\alpha. But how can we do this?
I do understand contraction in general, such that for a general tensor
T^{\alpha}_{\beta}=T^{\rho \alpha }_{\beta \rho}
But I don't see how this has been applied here?
Thanks in advance
p.s If this is more of a general maths question then please move to the appropriate forum
From your first equation,
<br /> \delta^\gamma_\alpha \left( R^{\alpha \beta}_{\gamma \delta ; \mu} + R^{\alpha \beta}_{\delta \mu ; \gamma} + R^{\alpha \beta}_{\mu \gamma ; \delta} \right)=0<br />
Now do the sum over \gamma.
Wow, thank you! 4 of us working together didn't think of that :(
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
