Contradiction on electric field ?
amrice
Hello, I'm have just started on this subject, and I am confused with the following equation:
since E(t) = kq(t)
=> [tex]\frac{dE}{dt}[/tex] = k [tex]\frac{dq}{dt}[/tex] = k*I
=> E = [tex]\int(kIdt)[/tex]
so if there is a constant current, wouldn't my electric field blow up??
Thanks!
Hmmm, it seems that you have defined current improperly. The situation you described is if you had a point charge somewhere in space at t=0, you'd have some electric field from that point charge. Your dq/dt is equivalent to somehow magically increasing the charge of that point charge, which is unphysical and not current. But yes, if you could magically increase the charge indefinitely, the electric field would blow up at t=infinity.
