Control circuit using pic 16F84
In summary, the conversation discusses how to ask questions on a forum and how to obtain a program to control a keypad. The individual asking the questions is advised to do some research on their own and is given a link to keypad information on Wikipedia. They are also encouraged to learn about keyboard scanning and using a microcontroller for this purpose.
lusy
how can u ask questions in this forum?
can u please give a program that will control a keypad
You just did.
CS
Can you be more specific as to what you want?
CS
We don't give out answers to homework/coursework problems here on the PF, lusy. We are willing to give you tutorial help, so that you can figure out the answers to your assignments yourself, however.
So here's a basic link to keypad info on wikipedia.org, with other links:
http://en.wikipedia.org/wiki/Keypad
And you should also do some reading about how keyboards are scanned, and why there are diodes in the row/column arrangement of the key switch circuits. After you do that reading, it should be pretty apparent how to use a microcontroller (uC) to do the scanning.
1. What is a PIC 16F84 microcontroller?
A PIC 16F84 is a type of microcontroller developed by Microchip Technology Inc. It is a small, programmable device that can be used to control electronic circuits.
2. How does a control circuit using a PIC 16F84 work?
A control circuit using a PIC 16F84 works by using the microcontroller to send signals to other components, such as transistors and sensors, in order to control the functioning of the circuit.
3. What are the advantages of using a PIC 16F84 in a control circuit?
One advantage of using a PIC 16F84 is its small size, which makes it suitable for use in compact electronic devices. It is also low-cost and easy to program, making it accessible for hobbyists and professionals alike.
4. Can a PIC 16F84 control circuit be used for different applications?
Yes, a PIC 16F84 control circuit can be programmed to perform a variety of tasks and can be used in different applications, such as robotics, automation, and home automation.
5. Is programming knowledge required to use a PIC 16F84 control circuit?
Yes, some programming knowledge is required in order to use a PIC 16F84 control circuit effectively. However, there are many resources available online for learning how to program this microcontroller, and it is relatively easy to learn compared to other microcontrollers.
  • General Engineering
  • Electrical Engineering
