Conventional square and triangular LEDs
  • Thread starter Thread starter greynoon
    Leds Square
Conventional square LEDs are generally less efficient than triangular LEDs due to factors like total internal reflection and the geometry of light emission. The shape of the LED affects how light exits the device, with triangular designs potentially allowing for better light distribution. The efficiency of an LED is influenced by the refractive index of the materials used, which can cause light to be reflected back into the semiconductor, increasing heat and reducing efficiency. Additionally, using transparent substrates and reflective layers can enhance light extraction. Understanding these principles is crucial for improving LED performance.
greynoon
Could someone please differentiate this to me? "Why Conventional square LEDs are less efficient than triangular LEDs.
If any of you guys could help me out, or point me in the right direction, it would be a great help!
Thank you in advance!
Yikes. I have an idea, but I need to know if this is a homework/coursework question first. We handle posts differently if they are for homework/coursework.
What is the context of the question? What are your thoughts on it so far? What factors go into the efficiency of an LED, from electrical energy to the final light energy that makes it out into the air?
This question i asked is neither coursework nor homework. I came along this question after perusing on some past year assignments which really triggered me. I just want to have a knowledge of the diffrences in the LEDs.
My thoughts so far are: It has something to do with total internal reflection or snells law!
That was my thought as well. The most efficient would be the rounded top traditional LED shape (that's why they are round in the first place). To contrast the square and triangular shapes, you'd need to do some 3-D ray tracing to see what the exit path options looked like.
Substrates that are transparent to the emitted wavelength, and backed by a reflective layer, and light spreading layer, increase the LED efficiency. The refractive index of the package material should match the index of the semiconductor, otherwise the produced light gets partially reflected back into the semiconductor, where it may be absorbed and turned into additional heat, thus lowering the efficiency.
http://en.wikipedia.org/wiki/LED#Light_extraction"
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
