Converge or diverge of factorials
  • Thread starter tnutty
  • Tags
    Factorials
In summary, by decomposing n! and using the comparison test with the geometric series, we can show that the series \sum\frac{37}{n!} converges.
tnutty
326
Determine whether the series converges or diverges.
[tex]\sum\frac{37}{n!}[/tex]
I will just forget about the 37, and think of it as [tex]\sum\frac{1}{n!}[/tex]
I can try to decompose the n!
n! = n(n-1)!
n! = n ( n-1) (n-2)!
n! = n(n-1)(n-2)(n-3)...2*1
so [tex]\sum\frac{1}{n!}[/tex] = [tex]\sum\frac{1}{n(n-1)!}[/tex]
[tex]\frac{1}{n}[/tex] *[tex]\frac{1}{(n-1)!}[/tex]
since 1/n is a p-series and diverges so does the series.
Is this right ?
That's not a p-series. A p-series looks like 1/n^p. Use a ratio test.
Don't know what a ratio test is. Isn't 1/n a p-series because
1/n = 1/n^1 ?
Your series isn't 1/n but 1/n!, can you see the difference?
yes but
its 1/n * 1 / (n-1)!
if one term diverges, does not the other because Infinity * whatever != converge
Well, nope!
1/n*1/n^2=1/n^3. this series obviously converges, by applying p-test
Eventhough the first one alone(the harmonic series diverges)
Moreover: 1/n*1/n both alone diverge but when multiplied together they converge , 1/n^2 according to p-test again.
ok, so how do I go about this. Since I haven't learned ratio test yet
I assume you have learned the comparison tests, right? since this is one of the first tests you learn when you are introduced to numerical series.
first prove that:
[tex]n!>2^n[/tex] for some n>k, where k is a positive integer, and then use this fact and the comparison theorme to show that your series converges.
From using a graphical interface k = 4.
not sure how I can prove it.
I could try this :(induction)
0! = 1
1! = 1
2! = 2
3! = 6
4! = 24
5! = 120
2^1 = 2
2^2 = 4
2^3 = 8
2^4 = 16
2^5 = 32
well, since n!>2^n, for say n>2, then it follows that
1/n!<(1/2)^n, and you probbably know that the RHS is a geometric sequence whose ratio is r=1/2<1, so it converges, now from the comparison test, we know that the series sum(1/n!) converges as well .
What is the definition of "converge or diverge of factorials"?
The term "converge or diverge of factorials" refers to the behavior of a sequence of factorials, which are numbers obtained by multiplying a series of consecutive integers. More specifically, it describes whether the terms in the sequence get closer and closer to a specific value (converge) or if they become infinitely large (diverge).
How is the convergence or divergence of factorials determined?
The convergence or divergence of factorials is determined by examining the ratio between consecutive terms in the sequence. If this ratio approaches a specific number as the terms increase, the sequence is said to converge. If the ratio approaches infinity, the sequence diverges.
What is the difference between convergent and divergent factorials?
The main difference between convergent and divergent factorials is the behavior of the terms in the sequence. In a convergent sequence, the terms get closer and closer to a specific value, while in a divergent sequence, the terms become infinitely large.
Can factorials both converge and diverge?
No, factorials can only either converge or diverge. It is not possible for a sequence of factorials to exhibit both behaviors.
What are some real-world applications of convergent and divergent factorials?
Convergent and divergent factorials have several applications in mathematics, physics, and engineering. For example, they are used in the study of infinite series and in the determination of the convergence or divergence of integrals. They also have applications in calculating probabilities and in the analysis of growth rates in various fields.
